Duplex is turned off on my c350 - Office Equipment & Supplies
    President:
  • Office Equip... Master
  • 990 Answers
The answer is " YES "
Posted on Dec 11, 2008
  • Everett Lin Dec 11, 2008
    when you don't hit the duplex key is on sleeping mode.
Duplex bizhub driver
In Printer Perfrances select back to back or double sided make sure you also select Binding Left for printing second side and you don have to flip the paper over or Top Binding like a lesson top lecture note book
Sep 03, 2013 | Minolta C350 Printer
When printing duplex A3
If you have the duplexer installed and can use it in the copy mode fine then you probably don't have it installed under you printer setup screen. Just go to printers&faxes in Windows. Double click on the C350. Then click on properties, then upper left should be a configure or advanced tab which lists all the installed options. Make sure that duplex unit is installed and not disabled.
Apr 07, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do you print a two sided document on the bizhub c350
right click on the installed printer icon, then go to "properties", then in "printing preferences", check the duplex option box, and further settings
Mar 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
I'm wanting to print two sided copies from my computer to the Konica Minolta c350 and can't find a setting that allows me to do so.
It's possible that you don't have all of the drivers installed.
In some cases, there is a simple driver and then a more complex one (such as an EFI Fiery) that will open up the rest of the printing/finishing options for you.
If you've delved into the printer "properties" and "advanced" buttons with no luck (be sure to look for the word DUPLEX), then I'd look into an updated driver.
Oct 13, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 gives error code C-OF36 while making duplex copies . M achine will produce half a dozen copies, then return the error code.
that code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
Sep 23, 2009 | Konica Minolta Office Equipment & Supplies
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I need motorola c350 tools
The Motorola c350 and c350 World phones are no longer supported by the Motorola Phone Tools program.
I will see if I can locate an English version of the Phone Tools program you need.
Jan 07, 2009 | Motorola Mobility C350 Cellular Phone
55 people viewed this question
k24674
jasbo
jasbo
