Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca hd52w59 powers off / need small signal board?
Our 2 year old hd52w59 coninutally powers off and restarts by itself.  A "RCA authorized" service center says it needs a small signal board ("271850R")  but they discontinued and unavailable.  Is this possibly my problem? Are they available anywhere?  Is this a do-it-yourself job?
Thanks
  • 3 Answers
Http://www.ptscorp.com/ can take care of n/a issues for you.
Posted on Dec 13, 2008
Thanks for the response!  Are you saying it's definitely isn't the SSB, but the PS board?  The boards are not stocked at UED.  Checking/replacing the caps will do it?
Posted on Dec 12, 2008
  • RCA Master
  • 5,138 Answers
Deflection/power supply board cost 196.00 - SSB 253.00 has tuner on it--------- power board has Flyback transfomer, Check this board capacitor cp150 2200uf 16 v if it is bad you have 2 more caps in same circuit that need to be replaced also 220uf 35v ,there is 3 caps all together cp150--,cp111 or114-- cp120 call UED for parts 1-800-648-6657
  • ladywinn
    ladywinn Dec 12, 2008
    I am almost 100 percent sure they gave you the number for the power/deflection board ,so check capacitor cp150 it will be 2200uf 16v if it is bubbled up on top itis bad,sometimes the bottom bubbles out too. So if this is bad replace the 2 other capitors in same circuit cp-111-114 220uf 35v------- cp120- 220uf 35v
  • ladywinn
    ladywinn Dec 13, 2008
    Let me do some more checking around and see if there is another place to get boards rebuilted.get back to you asap.
Small signal board for RCA HD52W59
Thats caused by the small signal board located on the right side of the set ( Green board with the RCA plug inputs on it. Very common issue with that chassis. The board will have a barcode sticker with an as222 number. You can get replacement boards and any part needed for that model from www.tvrepairworld.com
Jan 28, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have rca hd52w59 that has mind of its own. Turns volume down but not up. Turns TV on but not off. Flashes menu screen on and off. Screen formats changes, etc etc. Is the TV shot or is there a relative easy...
Thats a very common problem with that model which is caused by the small signal board needing replacement. Several version of small signal boards were used in that chassis but the people at www.tvrepairworld.com have replacement signal boards and will help you determine which version you require for your specific version if your not sure.
Jan 04, 2012 | RCA HD52W59 HDTV Projection Television
The main menu on my RCA hd52w59 keeps flashing on and off. I cannot get it to stop.
Thats almosy always caused by a bad small signal board. You can get replacment small signal boards from www.tvrepairworld.com
Aug 20, 2011 | RCA HD52W59 HDTV Projection Television
We have RCA Model HD52W59 and the input cable end broke; is that replaceable?
Its possible to resolder the Connector but its a vert precise soldering. Its often easieast to replace the small signal board . You can get small signal boards from www.tvrepairworld.com
Nov 05, 2010 | RCA HD52W59 HDTV Projection Television
RCA projection HD52W59 won't turn on 2 green flashes at power but
Most techs dont know much about the ITC222A chassis which is what your model is. I would double check the ribbon cables that connect the Main deflection board and signal board. There are two of them just be sure they are proerly seated into their sockets as Those connections can cause that type of random operation
Jun 20, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV arcing internal high voltage tower help
http://www.riddledtv.com/repair/RCA.html
http://serviceman.site88.net/index_files/Projection.htm
try these sites see if they help u
need to know chassi
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
check the fuse its located on the small rectangle board which is on the right side looking in the back its the board closet to where the screen is.
May 12, 2008 | RCA HD52W59 HDTV Projection Television
Part number
you must have what known as yx extension it will be on the label in small letters hd52w59...yx1 yx39 or something like that
Feb 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
162 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
