Question about Vehicle Parts & Accessories
Remote starter stopped working
The remote starter (I chose 'security system' below as the best match) worked fine all last winter, now that it is getting cold again it is not working right. For a week or so it would only start the car if you were within 10 feet, now the only time it works is if I actually sit inside the car and hold the remote next to the little antenna on the windshield. I have 2 keypads, they both have the same problem.
I tried replacing the batteries in both keypads, and the problem has not got any better. I can start the car with the remote if I'm actually sitting in the vehicle. There has been no other work done on the car since before last winter when the remote starter was working fine.
I don't know the brand of the remote starter, it's an after market and my wife had it installed, she didn't get any instructions etc. Thanks in advance...
  • 4 more comments
  • bruce_diducc Dec 15, 2008
    Thanks to both of you for getting back to me.
    Unfortunately I don't know the make, and I looked up the remote on the web and it's an aftermarket unit.
    I did check the antenna wire and it seemed fine, but I tried pushing the antenna back into the houseing because it felt loose. The starter works fine now. With any luck I am all set, but if it acts up again I now know where the problem is.
    Thanks again!
  • Buck 16 Jan 10, 2009
    Code Alarm stopped working after truck sat for about a week in cold weather. Batteries are fine, and truck starts with the key with no problem.
  • jimothyinnot May 11, 2010
    Do you know the make and model of the unit? If not can you post a picture of the remote at least? Kinda shooting in the dark here......
  • mikehumble May 11, 2010
    follow your antenna wire down and see if it has any damage
  • Anonymous Mar 21, 2014
    when I push the buttons, it doesn't work right away but only keeps blinking. Then after how many tries or a little tapping on it, it works fine
  • Anonymous Mar 30, 2014
    remote car starter stopped working then pulled out fuses and they were fine. then remote started car but shut off immediately
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 124 Answers
Will you rate my answer from my clarification as a solution about the antenna thanks Mike humble.
Posted on Dec 15, 2008
My remote start quit working all of a sudden. The lights and everything comes on like its supposed to but it doesn't start. The remote still locks and unlocks
My Remote Car Starter Stopped Working! - DON'T PANIC!
www.mobileedgeonline.com > Remote Car Starters
This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
So Your Remote Starter Stopped Working.... Just Relax!
www.wssdriveeasy.com/remote-starter-stopped-working/
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
My remote starter is not working, how do I fix this? - Compustar
https://support.compustar.com/.../202533874-My-remote-starter-is-not-w...
When your vehicle's remote start stops functioning the solution can change depending on each situation. The Compustar remote will not...
Remote Starter Won't Start - YouTube
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
remote start problems - YouTube
Jan 14, 2016 | Cars & Trucks
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
Car won't start, makes clicking sound
If you have a bulldog remote start, you should have it removed right away. I work at best buy, and we will not install these any more because of the problems they cause. You should buy something made by DEI, they cost a little more, but are very well made and come with a lifetime warrenty.
Aug 17, 2009 | Remote Starter with Keyless Entry
Broke remote and bought new one
lick on this link and go to contact us . call tech support and they will help you. http://www.bulldogsecurity.com/
Jan 16, 2009 | Remote Starter with Keyless Entry
My tahoe alram just stop working the remote is working fine
Probably the remotes battery is dead , use a key or something flat to pry open the remote fob , inside is a button cell battery .
Nov 27, 2008 | 1995-1997 Chevy Tahoe Ignition Starter...
2000 olds Intrigue gx
The key security uses a series of specific resistors values one appears in the run position and the other in the start position of the key. These resistor values are not of standard values. Some times when a tech installs a remote start they measure the resistor values from the original ignition key and try to pair a set of resistors to match. If they are close the system will work most of the time. However, hot and cold temps may make them drift so the MCU will not accept them. Also these external resistors run through relays of the remote car starter, if the contacts get dirty this will also change the resistor values. Best place to look for answers is with a remote car starter book about defeating the key security for remote start.
Oct 19, 2008 | 2000 Oldsmobile Intrigue
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Vehicle Parts & Accessories Logo
1,628 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
