Question about HP PSC 2355 All-In-One InkJet Printer
Print carriage jams
I have an HP PSC2355 all-in-one. The carriage jams randomly. But when it jams, it repeatedly jams numerous times before I can get it to print. I have been opening up the door and manually sliding the cartridge carrier to another location until it finally prints again.
Has anyone else had this problem? Is there a quick fix for this?
  • Anonymous Dec 30, 2008
    Exact same problem!!!!! Nothing seems to correct the problem.
  • Anonymous Mar 19, 2009
    Did all this and still doesn't work. its 4 years old maybe its done.
    The little screen lights on but the "on" button isn't lit and printer wont even print now
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC2355 all-in- one printer Carriage jam
Try to move the carriage manually..it works most of the time....if still does not work...replace the printer.
Nov 25, 2008 | HP Office Equipment & Supplies
Carriage jam
Hi...
Try to move the carriage maually left and right ..still does not work...service the printer.
Regards
debroy
Nov 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp officejet 7210 allin one,carriage jam,tried all hp troubleshooting
I had a "carriage jam" error message.
My son gently wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, took the drive belt off/put it back on (not easy), and found nothing wrong with it. So, I put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
You might also check the belt to make sure that there is nothing that might cause it to hang-up.
Kevin
Nov 24, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
My son wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Aug 13, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
I had a "carriage jam" error message. I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Jul 19, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage Jam
I FIXED MINE YES... open your thing.. and look,... do you notice..
theirs like a small black.. corner shaped thing, that stopped the carriage..
pop that thing like add force to push it back...
boo ya. :) and their you go...
this problem annoyed me for a month. and i went through numerous hp printers too.
but, just...... really open your eyes and try to find out whatsup..
:) woot woot woot imma print stuff now.
Nov 01, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
145 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
