Question about Motorola Mobility RAZR V3
My RAZR Phone is haunted
My RZAR phone has display problems. it shows a messed up color display backwords numbers and some times it is just fine.can anyone help?
    Brigadier General:
  • 7,752 Answers
Just take the phone and have the lcd replaced from a mobile service center.
Posted on Dec 28, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is a repairable issue. However not recommended to DIY. There could be three basic causes for the malfunction.
1. Bad LCD
2. Damaged flex cable
3. Faulty mainboard.
What to do: Send your phone to an authorized reputable Cell Phone Repair Shop.
My recommendation: www.CellularTechnicians.com - Truly the best 1-877-914-4001
One of the most important questions asked by cell phone technicians throughout the world when an end user complains of cell phone trouble is: Has an incident occurred to the device that would cause it to begin to malfunction?
ie Dropped, Exposed to liquid / moisture. What happened to it, how it happened and has there been an attempt to fix it yourself.
This helps in the attempt to diagnosis the cause for the malfunction without a visual inspection. The objective is to provide the end user with professional advice, personal recommendations and repair cost estimate if the device is indeed repairable.
Good Luck,
ERIC the PHONE GUY
Dec 11, 2008 | Motorola Mobility RAZR V3
Strange issue with Motorola Razr
it also happened with my sony erricsson t230. i believed it is some kind of bug in there messing with ur phone.
Jul 09, 2008 | Motorola Mobility RAZR V3
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Screen & working
my motorola RZAR hand set is screenserver on time not dispaly screen
May 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NO DISPLAY
i have the v3i and it had the same problem its usely the flex cable that messes up if its opend some times fast the screen gos white if you change the flex that should solve your problem . arubinoff1@yahoo.com cumputer tech
Nov 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Time display
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
Nov 19, 2007 | Motorola Mobility RAZR V3
Front screen not displaying anything
I would go back to where you replaced the front screen and let them know that they did not fix the problem. Let me know what happens. No easy way to fix.
Cynthia
Nov 05, 2007 | Motorola Mobility RAZR V3
Frozen Alltel RZAR V3m
you can have them replaced the flexcable also allow them to reflash your phone for you....this should correct the issues you are having with the phone...just take it to any mobile service center and have them repair it for you there.
Oct 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr V3M's external display not showing wallpaper. iTunes help too!!??
As far as I know only razr v3i has i tunes. as far as the external display not showing your wallpaper as the internal screen i'm not sure except if it dosen't show the time and stuff on the external display your screen's connector for your display may be loose if so thier should be a solved problem for that.
Mar 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
