Question about Carrier 38CKC042 Air Conditioner
Tonnage of my Carrier AC Unit
I would like to know what my tonnage is for my Carrier AC unit. The model number is 38CKC042300
  • crowsplace20 Dec 11, 2008
    Thank you so much for the quick reply. I really appreciate it.
  • 306 Answers
3 1/2 ton unit the 042 tells me.
Posted on Dec 11, 2008
  • Ken Bledsoe Dec 12, 2008
    I appreciate the rating so many people you help out what you can don't even give you any feed back so thank you crowsplace20
38yxa042300 trying to figure out what is the ton of this ynit?
Posted on Jan 09, 2010
How many tons my ac model 38MKS60Ds20/01
Posted on Aug 03, 2014
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can't find this info on the tag.
Did you include the make and model information?
I only see your question worded this way:
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can\'t find this info on the tag.
Tell us more-- or go on line and do a search for the make and model-- Can you do that?
Mack B.
Dec 28, 2010 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
Can't find the tonnage on a mdl. 48G6-042090301
Usually the date plate is mounted on the A/C unit near the power connection. Sometimes you have to remove the access plate for the electrical connection to view the data plate and othe information about the unit.
Just be sure you kill the power to the A/C before you go opening up the access cover to prevent getting bit by the 220V-AC voltage inside!
Hope this helps and best regards!
Jul 31, 2009 | Carrier 38CKC042 Air Conditioner
I would like to know what my tonnage is for my Carrier AC unit. The model number is 38BRC350
You have 3.5 ton unit. Just divide 12 into the 42. 12,000 btus is one ton of ac
Jun 13, 2009 | Carrier 38CKC042 Air Conditioner
Tonnage of unit
Listed at Carrier at 2,330 Kilos so math says 2,330 X 2.2 = 5,126 lbs or about 2.5 tons though they listed it as a 3.5 ton max back when they sold this model.
May 12, 2009 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
5,296 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
