Question about Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook
Xerox 214 dc
The copy are grey ,not blak .
    Novelist:
  • 166 Answers
It means the cartidge alignment is dis-balanced. So you need to fix it and may be re-fill cartidges also.
Posted on Jul 21, 2009
How do i get rid of streaks on copy. There are 3 black streaks on each copy. I have a xerox 420dc
Print heads need deep cleaning. If not ink jet, then the drum is damaged (scratched) and needs to be replaced to eliminate the bogus lines.
Jan 17, 2017 | Xerox Document Centre 420 DC Laser Printer
Xerox 6125 prints out grey instead of black. Changed black cartridge from an OEM copy to an original Xerox, still does it
you have the wrong drivers installed ie monochrome i have had this in the past with other printers make sure you have the colour ones
Jun 06, 2011 | Xerox Phaser 6125 Laser Printer
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
A blak line on the copies??
raise the control panel and look for white out and stricks on the mirror or glass. jaime
Jul 08, 2010 | Ricoh FAX2900L Plain Paper Laser
Have a 214 xerox copier get e5 error and it will not reset
Remove the copy cartridgte and look on the right side of the machine. Clean all the contacts you see with a soft cloth, maybe lightly saturated with alcohol.
Then on the door where the copies exit, open that door, you will see a metal, sawtooth shaped piece of metal, just before the paper exits the machine on that door. Take a brusk and gently clean the black ink off that sawtooth. Normally what happens is that builds up with ink and starts to arch causing the E-5 code.
You may want to check the socket that is one the upper left portion of that door to inspect the contacts for damage.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox XG-70D
Remove the 2 screws near the bottom on the back.
Place the monitor face down on a towel with the 2 screw holes near you.
Push the grey plastic back cover away from you whil holding the glass front in place on the towel and the back will lift off easily.
Aug 18, 2008 | Xerox XG-71D 17" Flat Panel LCD Monitor
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox Copier 214
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fiser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Jan 29, 2008 | Xerox WorkCentre 214 Laser Printer
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
