Question about Goodman CLQ36AR49 Air Conditioner
Wireing code from goodman heat and air to a Hunter 44360 programa
I have a Hunter thermostat # 44360 and I want to hook it up to a GoodmanMODEL#AWB24-05C-REV-E
SERIAL# 0304723436.
Someone too the old theromastat off and did not mark any wires coming out of the wall.I am at a loss trying to hook this thing up.
7 Wires from wall: Lt Blue,Black,Yellow, Orange, Green, Red,White.
The thermostat wall plate terminals are are from left:G RC RH Y/O W/B Y1 and A jumper goes in there somewhere.I am on a very fixed and unable to pay.Please help will be apprecated.
Jack in S.C.
  • 1 more comment
  • jselsey1 Dec 12, 2008
    Skeeter,I havelooked aat the board and this is the best discription I can give you on the left of the board is:Green in front, Blue is next terminal, 3 pink on the next terminals.I can see no other markings to identify.
    Jack
    Yes I do.It isonly a small board.
  • jselsey1 Dec 13, 2008
    Yes,but right now in South Carolina the last week has been hot during the day and really mild at night.Been lucky that it has not been too cold a couple mornings of frost but not bad
    Again thanks for your help
    Jack
  • 306 Answers
To get your heat going take the red wire hook it up to R on t-stat. Take white wire and hook it to W on t-stat. Take the green wire and hook it to G on t-stat. that will get you heat. Now I need for you to go to the unit where the wires hook to the furnace circuit board. I need to know what color wires go to what on the board. Might have to take off bottom panel. should only be using 4 or 5 wires. Get back with me and will complete the wiring. Be sure no wires at the t-stat are touching each other as this will short out transformer. So tape them off or cut flush so wire and insulation are flush. ken
Posted on Dec 11, 2008
  • Ken Bledsoe Dec 12, 2008
    The lower section where the blower motor is located is where the circuit board is located. Do you see anything like that.
  • Ken Bledsoe Dec 13, 2008
    Did you get heat?
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
How do i get my carrier thermostat # R ,Y/Y2. G , C , W/W1 into a Hunter thermostat model 44360?
First off hunter is a very problematic brand I recommend taking it back and get honeywell or white rodger you will thank me in the long run trust me. As far as the wiring goes R terminal which is typically red which is 24v power connect to R on t- stat hook Y which is usually Yellow to Y terminal G is green W is white,
R= power 24 V
Y= cooling
W= heat
G= fan
C= common only used if t-stat does not require batteries.
If this help please rate me and do a testimonial.
May 23, 2011 | Heating & Cooling
I bought model 44360 thermostat need wiring diagrams for 7 wire heat/cool system
what name brand t- stat is that let me know i can get a wire diagram
Apr 03, 2010 | Hunter Heating & Cooling
I have a Ruud air handler and i'm trying to use a
The 44360 tstat can be used for single stage Heat pump use only. Unless you are in an environment that has greater than 40 degF outdoor temperatures year-round, you will want to return that tstat and obtain a multi-stage Heat Pump tstat. The standard system is 2-stage......1st stage is Heat Pump Compressor and 2nd stage is the backup electric heat.
Hope this helps. Good Luck. :-)
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42710.pdf?n=149
Feb 21, 2010 | Heating & Cooling
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Oct 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermo smoked when elec. turned on
Where are the wires connected in the heater ? They should be on R and W, if the W is on C you are shorting the heat anticipator in the thermostat. If the unit is wired right look for a spot where the wire is rubbed thru and touching the metal housing of the heater.
Aug 22, 2009 | Hunter 30124 Air Conditioner
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need a user guide/owners manual for a hunter thermostat - model 44360. Any suggestions?
Most manufactures have all their manuals available (for free) online, if you have trouble finding their site, try google or your fav search, good luck, Chuck
Mar 16, 2009 | Hunter Fan Company 7-day programmable...
Goodman CLQ36AR49 Air Conditioner Logo
150 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
