I have an Akai CD-A30. When I put the CD in and push play it goes to 01, play button starts flashing, can hear cd spinning, then the cd automically goes to the last number on the track and stops. Never actually engages. Any suggestions?I have tried a cleaning cd already and no help, it did the same thing?
    Genius:
  • 1,268 Answers
Try to use a different CD. Look for Random Track setting on the player and disable it or turn it off.
Posted on Dec 11, 2008
  • 395 Answers
Did you check the cd for sctatch's, does it do this with all cds or just 1, it might be a bad laser or one thats about to fail
    Master:
  • 479 Answers
Its the problem of the lens that is not reading the cd properly.either the lens is dirty or the lens is faulty.needs replacement.
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
ITS cd tray is revolving when we press insert button . tray moves inward and it do't select any cd .and tray comes out again. main problem is it do't select any cd
You have a slack loading belt under the tray.The loading action is not being completed because of it.
The Cd lifting mechanism requires more torque than the tray rotating action. If you put your ears close to the tray you will hear a belt slipping sound after the loading tray goes in . If you push the disc motor assembly with your hand from underneath the action sometimes get completed and the cd will start playing. Any way you cannot be doing this all the time, the belt needs changing. Its a set of two belts, one very small for the tray rotation and a thicker/bigger one for loading mechanism.
Mar 11, 2011 | Aiwa Audio Players & Recorders
JVC car stereo won't play cd
If it does it with any cd and it played before you have to clean the lense or laser. Get a cd player laser cleaner disk or cd. If you still have problems take the radio fuse off in the fuse block to restart it. Remove the fuse wait five minutes then reinstall. Also some times when you burn CDs in the wrong format the cd player will not recognize them.
May 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Put a CD in and get message that says ER (Error?)...every CD that goes in spins, but does not play.
could be one of 2 things
use a cd lens cleaner to clean the laser lens .
or could be warped or damaged cds and player wont play them
also if they are burnt cd the player may be to old to read them.
Apr 26, 2009 | Audio Players & Recorders
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
Cd player problems
I installed a dual xdm7510 reciver in my car and it worked fine for a day but now it will not play anything. Sometimes it will play and sometimes it will just eject any cd that I put in it. write me at jefferysprouse@yahoo.com
Sep 07, 2007 | Alpine CDA-7995 CD Player
GE 7-5295 CD error
i have the same problem exept that also the eject button is not working or the stop buttton.
Sep 25, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
239 people viewed this question
 Grubhead
Grubhead
