Question about Kenwood Radio Communications
Changing a radio case
I have a kenwood tk 272g vhf handheld with a cracked case. i have a new case. how do i change it? thanks
  • Anonymous Mar 16, 2014
    software for tk-272g
    i need tk-272g software
    New Friend:
  • 109 Answers
The TK272G is just like any other handheld it is just a matter of taking the radio apart and remembering or make notes of what you did. Start with removing the knobs on the top of the radio and then remove any screws that are under the battery compartment the radio should easily slide out of the case by using a screw driver at the bottom of the radio. Slide the scewdriver between the radio chasis and the case and the radio chasis should lift out. be careful not to bust the rubber seal O-Ring that may be between the radio chasis and the case. the rest should be easy for you to do. the key thing for you to do is take your time and remember the steps you have taken and reverse them when putting the radio back together.
Have a great day!
Patrick Patterson
Posted on Dec 16, 2008
How to reprogram a kenwood tk3000 read/write protected.password forgoten
Typically, you need to take a radio with a password to a dealer who has the Factory software. They can get past a password issue using their Kenwood software.
Nov 01, 2015 | Kenwood Tk-2000 Tk-3000 Vhf Uhf 5w Radio...
MY kenwood tk 272 g will not play audio while recieving. But i know the speaker works but i only hear it squelch on one channel
1 try to check the volume button is not fouled.
2 try to do reset by the manufacturer. (With station stopped ,pressing the two buttons on the side station . Starts station for 2 sec. Releases the side buttons.
3 try to do the firmware update.
Apr 21, 2015 | Kenwood Tk272g Tk-272g Vhf 150-174
Can I reprogram my tk-2400 with my PC?
No. It is programmed from the Factory on a chip. Preprogrammed. No software will change it, no hacks. Many Motorola radios like that too. It is two watts, Vhf of Uhf, you did not say. If your existing frequencies are Business Band and in the same frequency band (Vhf or Uhf) you can get it to match those.
Oct 13, 2014 | Kenwood Radio Communications
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
How do i progam a new channel or find out what chanel it has programed already
Hi Robin,
I take it the you require programming software for your radio, May I suggest: join yahoo group specific to your radio Make/Model, they will be able to give you all the info plus you can download manuals, schematics and other goodies.
I hope I have been of help.
Feb 03, 2013 | Kenwood Tk272g Tk-272g Vhf 150-174
Kenwood tk-272g radio wont transmit
This is commonly a sign of a bad or poorly charged battery. Check your charger, battery and battery contacts. Clean contacts with a pencil eraser. Try recharging the battery, making certain the radio is turned off while on the charger. If this does not solve the problem, try swapping batteries with a known good unit. If the swapped battery solves the problem, you know you need to replace your battery and/or charger.
If the problem remains with the swapped battery, you know you have a radio problem. In this case, you will need to look at the battery contacts on the radio, where the battery meets the radio and see if you see a problem there. OR a problem with how the battery fits to or in the radio.
If it is a radio problem, you may need to see your local Kenwood dealer for assistance.
Best regards.
Jul 14, 2012 | Kenwood Radio Communications
Can i leave my handheld on while charging its a TK-272g
It depends on the charger. If you hear a hum on receive when it's charging turn it off.
Sep 25, 2010 | Kenwood KNB-15AM,...
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
I have a kenwood tk-272g and the keys are locked and i cant figure out how to unlock them, the owners manuals ii found online aren't helping me at all
One of the keys has been programmed as the lock button. you will have to experiment by holding each button for a couple of seconds until you hear a tone that tells you the radio is unlocked.
On the one I have for our fire and rescue it is the < button but it could be any of the four on the front or the two on the side below the talk button.
Jun 12, 2009 | Kenwood KNB-15AM,...
Motorola and Kenwood compatibility....
Hello!! First of all, any radio in the right frequency will work with any other, to work just need the following features: -Frequency, 154.700 which is correct as you said. - the Squelch code, this could be PL or DPL. The XV2100 has a table of codes that you can try, as you dont know this code form the Kenwood, you will need to check one by one. If you have the chance to send the Kenwood to some to "Read" the radio parameters( freq.,Code, ETc) you can look those parameters on the XV. Hope this can help, any comments Good Luck
Jan 20, 2007 | Motorola XV2100 (1 Channel) 2-Way Radio
Radio Communications Logo
105 people viewed this question
Top Kenwood Radio Communications Experts
michael galang
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
