Question about Canon imageRUNNER C3200 Copier
Printing problem on Canon IR3200
All Excel files are printing w/o left margin, so text on left is getting cut off
  • 168 Answers
This is a common prob.. most of my users know wahat programs shift images and they adjust it accordingly... you may want to try some different drivers you may be using a pcl driver try a ps driver load accouple drivers up you can try the different ones go to by the way if you have a print server on the back of the copier you should use the imagepass C1 or C2 driver
Posted on Dec 11, 2008
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
I have the Brother MFC 8860DN. When printing it is missing out a large margin on the right hand side of each sheet and cutting off the text that would normally be in that section
Are printing with a MS excel file? If yes, go to page set up and click FIT instead of 100% size. To fit is in 1 page only.
Please ask me if did not help you
Mar 06, 2011 | Brother MFC-8860DN All-In-One Laser...
My Canon MP190 printer prints good, but at the left of the print the alignment is too much to the left, so capitals "fall off" the page. Canon says it is not a printer problem, but something else, but...
Click Start
Click All Programs
Click Accessories
Open Notepad
Click File
Click Page Setup
Check that the "page-margins" are not set to '0.0'.
Or, start Microsoft Word or Works or whatever "text-editor" that you use, and similarly check the "printer setup" for "left-margin".
Sep 20, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
Canon MP480 printer prints enlarged text and shifts page margin
hi. have you tried print from other pc. ? if still the same issue maybe is a internal problem with your printer
Apr 30, 2017 | Canon MP140 PHOTO AIO All-In-One InkJet...
I'm trying to print compact size directly from excel/word. What are the margins?
Step 1 Start Microsoft Excel and open an existing spreadsheet on which you would like to set the margins.
  • Step 2 Choose the "File" menu and click "Page Setup" to open the "Page Setup" dialog box. The "Page Setup" dialog box can be used to set up your page just how you would like it to appear.
  • Step 3 Click on the "Margins" tab at the top of the "Page Setup" dialog box to show the margins for the spreadsheet that you currently have option.
  • Step 4 Set the "Left," "Top," "Right," "Bottom," "Header" and "Footer" margins by clicking within the text box underneath each option to highlight the current margin setting.
  • Step 5 Type a new measurement for whichever margins you would like to change or use the arrows to move up and down throughout the measurements you can select for each option.
  • Step 6 Notice as you update each margin the preview in the center of the screen will change to reflect your new margin settings.
  • Step 7 Use your mouse to click the "OK" button to close the "Page Setup" dialog box and set the margins you have chosen for your current
  • Jul 07, 2009 | Computers & Internet
    Outlook Printing Problems
    open ie, change margins in file/page setup and try it again
    Apr 08, 2008 | Microsoft Office Outlook 2003 for PC
    Right Margin Does Not Print
    This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
    2nd option or
    Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......
    Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
    Canon imageRUNNER C3200 Copier Logo
    228 people viewed this question
    old marine
    old marine
