Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubshi vs50607 picture flickers and after some time shuts off and won't turn on for about 1 half hr.
  • Anonymous Feb 10, 2009
    I have a VS-50607 Mitsubishi rear projection it started flickering the next day when I went to turn it on all I got was a faint light no picture and no sound...
Bad connections on deflection yolks will cause this prob
kinda tricky to resolder but anyone handy with an iron could do it
Posted on Dec 23, 2008
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Sound but no video
Sound like you have a faulty inverter. The next time the picture turns off, turn off the lights in the room. Take a bright flashlight and shine it on the screen. If you still see a faint picture, more than likely you have a fault with the inverter.
Jun 12, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
. I bought an Amcor AWS090HR a couple of years ago
?Call pridiom group 201-266-8234 option 2 for warranty and service
?*Self Diagnosis Functions*
Our company provides the thoughtful services for customer,air conditioners had been
installed self diagnosis system to display the information for the units.
INSTALLATION & REPAIR GUIDE
Split Wall-Mounted air conditioner
8
*According to the service conditions and operating environment , the inside of the air conditioner
will become dirty after several seasons (3 to 5years ) of service , resulting in decreased operating
performance .Inspection and maintenance are recommended in addition to usual cleaning (The
air conditioner can be used for a longer period and without anxiety .)
*As to inspection and maintenance , consult your dealer or any one of business offices of dealing
companies .(Service charge is required in this case .)
*We recommend to perform inspection and maintenance during an off seasons.
*Choose the place where hot air and operation noise from the outlet of the outdoor unit do not annoy
the neighborhood .
*Things left near the outlet and inlet of the outdoor unit cause malfunction or increased operation
noise . Do not leave obstacles near the outlet and inlet .
*If irregular sound is heard during operation , consult with your distributor .
*Inspection and Maintenance
Note:Above self check information is commonly applicable in our most air conditioners,but some
are special,you can refer to the User's Manual for information or contact the dealer or authorized
maintenance people for help.
Digital self-check code/
(Polychrome screen self-check code)
Hint to defrosting Flicker 1 time/1s
Hint to defense
against cold wind Flicker 1 time/3s
Failure of room
temperature sensor
Failure of coiled
pipe sensor
Abnormality of
outdoor unit
Without feedback of
internal fan motor
Zero crossing signal
without current
External feedback
failure
Overheat protection
Water pump failure
Self-check code of luminotron/
(Self-check code of running lamp)
Flicker 2 times/4s
(Flicker 2 times/8s)
Flicker 3 times/5s
(Flicker 1 time/8s)
Flicker 4 times/6s
(luminating)
Flicker 5 times/7s
(Flicker 6 times/8s)
Flicker 6 times/8s
Flicker 7 times/9s
Flicker 8 times/10s
Flicker 9 times/11s
Self-check
information
Indicates "dF"or defrosting
indicator displays
Fan motor picture not running
E2/(L2)
E3/(L1)
E4/(E5)
E5/(L6)
E7
E6
E8
E9
Nov 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Realy chattering in Sony WEGA Trinitron
Hi, that is probly a capacitor in the power supply section near the relay, he failed to keep it charged
whit a good capacitor tester wizard you must be able to find and check for cracked soldering around it or directly on the relays
good luck and hope that will help you/
that is not an expensive repair;half or 1 hr time....
Mar 30, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Screen turns blank all of sudden and works normal after switching of the system for 1 hr or so.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 12, 2009 | HP Compaq dx2250 Microtower - Get 3...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Sep 24, 2006 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
