Question about SanDisk Sansa e260 MP3 Player
Battery Problem??? My new Sansa E260 is giving me a message that says "Battery is too low system shutdown". However, I was able to download music from Rhapsody, and while I was listening to it, it froze and this screen came up. When I plug it in to my laptop it shows charging to a full charge, however when I try to turn it on, I continue to get this same error. I hold the power button down to shut it off and it blanks out and the same message comes up and the blue light stays on. Please help!!!!
  • 3 more comments
  • Anonymous Mar 25, 2008
    Displays message Battery to low sytem shut down
  • covey95
    covey95 Jun 11, 2008
    it wont charge the battery and it drains while its off
  • LSRRAVI Nov 13, 2008
    i am not able to switch off my sansa e260 and it shows "Battery is too low System shutdown"
  • Anonymous Dec 25, 2008
    I have the same problem!
  • Anonymous Jan 06, 2009
    sansa fuze e250 3 weeks old. Loaded with music. Great! Now it wont charge at all. It says battery too low system shutdown. Plug into usb like usual to charge, nothing,black screen and it gets very very very HOT on the back of it!!!!!! Why wont it charge up?Thanks kn29
    New Friend:
Would this keep it from power on?
And is There a way to open it up to check/ replace battery???
Just to clarify this IS A HTC BLUE ATT CELLPHONE
Posted on May 28, 2015
Ok it takes a while but heres the solution. Slide the hold button to ON and hold down the REC button.While still holding the REC button,connect the USB port and wait for your PC to find it. Once it has found it type this link in to download Firm Ware. It may take a while but it is worth the wait.Once it is downloaded to your player EJECT!!! the player before disconnecting the USB port.Now just wait for it to format yor player and it should be working good as new again. =)
Posted on Mar 08, 2007
Ok it takes a while but heres the solution. Slide the hold button to ON and hold down the REC button.While still holding the REC button,connect the USB port and wait for your PC to find it. Once it has found it type this link in to download Firm Ware. www.sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe It may take a while but it is worth the wait.Once it is downloaded to your player EJECT!!! the player before disconnecting the USB port.Now just wait for it to format yor player and it should be working good as new again. =)
While charging it gives battery is too low system shutdown
Try charging for at least 4 hours when it is switched off.
Apr 07, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260- it says battery is too low. System
Having received no response in over a month, I assume this is no longer a problem.
Apr 26, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
Aug 05, 2009 | SanDisk Sansa e200 MP3 Player
Battery is too low system shutdown and it is plugged up to the computer
most likely your battery is burned up and will no longer hold a charge...two choices hire someone to replace the battery or try to do so yourself or you can trash it and buy a new one....hope that helps some
May 19, 2009 | SanDisk Sansa e260 MP3 Player
Royally screwed up e260
help! i have tried to download my copied cds through rhapsody & windows media player. nothing happens in rhapsody & windows gives me an error occurred message after each song when i try to copy to e260.
thanks for your input,
trish127
Mar 21, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e280
Have you tried recharging the battery? If it is not showing when you connect it to your computer, try holding down the Menu/On-Off button for 15 - 30 seconds and see if it goes on.
If you need a new battery this is a good place to get one:
http://www.jr.com/JRProductPage.process?Product=4153711
Feb 04, 2008 | SanDisk Sansa E280 MP3 Player
"Battery Is Too Low System Shutdown"
The battery has come loose from the contacts on the inside.
Remove the back (4 screws), remove the battery and put it back in securely.
Then charge it for a couple hours.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e260 MP3 Player
Error message " battery is too low system shutdown"
Try removing the battery from the back and re-seating it.
They become loose if they are dropped, or handled roughly.
Best of Luck.
Nov 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 won't let me download certain music
If you used Windows Media Player to "rip" (copy) the music to your computer. The default settings are to "copy protect my music" if you didnt change this setting, the Sansa will want a "license" to go with it. Resolution, change the setting in Windows Media Player, Tools>Options>Rip Music (uncheck copy protect my music). You can also change the default rip setting to Mp3, as opposed to Windows Media Audio. Then you would have to re-rip the tracks to your PC, as unprotected. Make sure you delete the old tracks from the device, otherwise, it will always give you that error message. Best of Luck.
Sep 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
523 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
