Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 - Freezer door will not close properly.
When all of the draws are in position and pushed in as far as they will go, the freezer door will not close properly. However, if only the bottom draw is in position the door will close. This problem appears to have devoloped recently and was not present when the unit was new.
It appears that the left hand side of the internal back panel of the freezer compartment has moved forward slightly and this is preventing the draws from being pushed in far enough to allow the door to close.
There does not appear to be any movement on the back panel and it seems to be firmly in position.
  • gt73 Jan 03, 2009
    Exact same problem with my freezer.Does anyone know if the rear panel of the freezer can be removed and cleared of ice/obstructions?
  • chrisannw Jan 10, 2009
    Hi we have the same problem,started about 6 weeks ago.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Posted on Jan 12, 2009
The same thing happened to my Hotpoint FFA70.
A huge block of ice has built up behind the back panel. This has made the back panel expand, thus making the drawers jut out too far. Like me, you may not think ice build up is the cause, since you cannot see any ice.
Action: Defrost freezer. Yes, I know its frost free, but wait an see! Take out al drawers, empty fridge and freezer and defrost overnight with doors open. The next morning, unscrew the back panel of the freezer. You will see 4 screws, 2 at the top, 2 at the bottom. These are not normal screws and are in an awkward postion at the top. Use pliers to grip and unscrew. Slide the panel forward and out. There! A massive block of ice! YOu will also see a hole at the bottom. SO that this didn't get blocked with all the water, I plugged the hole up using a ball of tissue wrapped in some plastic from a plastic bag (clingfilm would also do the trick). Use a hairdryer to melt the ice. Do not chip away at the ice as this might do damage. It took mine about 20 minutes to melt until a large block could be safely removed. Once you have dried the inside, unblock hole and screw panel back on. The drawers should now fit and the door close. I found I still needed to give my door a little help with closing it, but it did close and seal fully. All you have to do now is turn the fridgefreezer back on.
Hope this helps :)
Posted on Oct 01, 2009
I have posted this same problem on Jan.10th.We tried to remove the back to see if there was any obstruction but was unable to do so.Have rung the hotpoint help desk,they say they are unaware of this problem,& would only send an engineer out at a cost of £100 plus the charge if it could be repaired.We have now removed the ridge from the back of the drawers,which enables the drawers to fit properly & therefore the door now closes.Unfortunatly for some reason the 2nd drawer down will not fit evan with the ridge sawn of.Not a brilliant solution,but we are now able to use the freezer.
My freezer is on the bottom and it keeps building up frost. Any idea why? Just started about 2 weeks ago.
for frost to start appearing in a bottom freezer, indicates that the draw seal is not sealing properly or the draw is not closing fully
after 3 years it may need an adjustment of the rollers and slides to get the draw sealing better again
call in a service technician as it should be still under warranty
May 13, 2016 | Samsung 25.8 Cu. Ft. Side-By-Side...
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is causing loud whirring noise in FFA-70 freezer with high freezer temperature and is it likely to be economical to fix?
Think you will find. That ice build up is preventing door closure and also the fan is being obstructed by the ice suggest you empty freezer and defrost for at least 24 hours, be prepared for a lot of water as ice melts
Jun 04, 2014 | Hotpoint FFA70 Bottom Freezer Refrigerator
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hi my freezer door on FFA70 Hotpoint isn't closing. I have taken the draws out and defrosted it. The door closes when none of the draws are in, but doesn't when the draws are placed in their...
Hi, I had exactly the same problem and eventually realised that the panel at the back of the freezer was coming loose. When I removed it I found that all the parts behind the panel were covered in ice, a lot of ice! So I have defrosted this ice using bowls of steaming water (not sure if this is an appropriate way to defrost, but it worked fine for me), I have also read you can use a hair dryer to spead up the process - apparently if you try and chip the ice off it can damage the parts in your freezer. I have now fixed the panel back on the freezer and it is working like new and I have had this fridge freezer for years now.
Aug 02, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
When i close the refrigerator the freezer door opens. what causes this and what do i need to do to fix it?
you can try to raise the front legs a bit and put some heavy things on the rack on the door so it won't pop open.if the door opens and closes correctly this should help,also how is the gasket on the door?wash around the frame where the gasket touches the frame and wash the gasket,there's a magnet inside the gasket that helps hold the door shut.check to make sure no food or draws are sticking out to far and hitting the door when it's closing.
Mar 02, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icing of freezer compartment. compartment freezes and pushes doors open.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
1,459 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
