Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
I get "Limited or no Connectivity" when I connect via ethernet
I've just got this router, and to set it up you need to connect to a PC with an ethernet cable. But it just says "Limited or no Connectivity"
So whenever I try to access the router settings in a browser it doesn't load.
I've made sure all settings like "Obtain IP address automatically" are set correctly but it just won't work.
I've tried the same on several PCs and a MacBook with no luck.
I am running WIndows XP
  • arran_coe Dec 13, 2008
    thanks a lot for your reply. Unfortunataly though that doesnt work; it fails at the IP renewing stage of repairing
  • 30 Answers
Where it say limited or no connectivety icon on the taskbar just right click and select repair. hope this helps
Posted on Dec 13, 2008
Just bought a new Belkin 300N wireless router. My pc does not link to it all i get is a limited or no connectivity via Ethernet cable. Ive updated the driver checked all the standard settings all is...
GENERAL ROUTERS RESETING 1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Jul 30, 2011 | Belkin Powerline F5D4050 Network Adapter
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Internet says limited no connectivity when i plug my computer to wireless router through ethernet. am i doing something wrong?
Limited or no connectivity means that the computer is not recieving an IP address from the DHCP of the router. The very first thing I will suggest is to reset the router.
Press the reset hole on the back of the router for 10 seconds while it is powered on. Turn it off and then turn it back on after releasing the reset hole. The computer should show the connection as connected after that. However, you will have to reconfigure the router as resetting will revert it back to default settings.
Good Luck
Aug 08, 2009 | NetGear RangeMax Premium Wireless-N...
Connection problem. shows limited connectivity and disconnects
limited connectivity means you didn't get an IP address. Is the router set to give addresses via DHCP, or is another PC doing that? Most common cause of this problem is wrong authentication (normally "open") or encryption type (WEP, WPA or WPA2). Pklease note that encryption keys can be set as HEX or ASCII, if they are HEX it will be only numbers 0 to 9 and letters A-F. ASCII can be anything.
Jun 01, 2009 | NetGear DG834N Router (DG834N-100AUS)
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
No connection or limited connectivity
It may be that you have to set the router to enabe DHCP, as this will give your pc an automatic IP address. The original address settings will be different than that of your router, so go into your wireless network card properties and ensure that obtain IP adress automatically is enabled. You may also need to run the dns flush; Click Start>Run, then type ipconfig /flushdns then press enter.
Jan 06, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
179 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
