Question about GE Ovens
GE Profile Spectrum Duel Fuel Door is locked but not shut.
Control says locked but the door is not shut. I can't clear it or shut my door.
  • 71 Answers
There is a solenoid in the back or under the top that locks that. the monitor switch is controlled by this solenoid. For some reason that
solenoid is bad.
Posted on Dec 12, 2008
Oven is stuck in lock mode
Hi Lora, this is AP!
Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
    The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
    Rick
    Sep 03, 2011 | Ovens
    Can't open the oven door with an F9 and beeping
    Here's the info from the service manual
    "Fault Code: F9
    Likely Failure Condition/Cause:
    1. Door motor failure / jammed. Latch
    motor switch failure.
    2. Control software failure, or component
    failure (relay stuck).
    3. Wiring Problem.
    Suggested Corrective Action:
    1. Press CLEAR key.
    2. If CLEAR key does not eliminate problem, turn off power for
    30 seconds, then turn on power.
    3. Check wiring of Lock Motor, and Lock Switch A and Door
    Switch circuits.
    4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
    motor does not rotate, replace Lock Motor Assembly. Plug
    P4.
    5. Check Lock Switch A for proper operation (do they open and
    close, check with ohmmeter). The Lock Motor may be
    powered as in above step to open and close Lock Switch. If
    the Lock Switch is defective, replace Motor Lock Assembly.
    6. If all above steps fail to correct situation, replace control."
    Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
    How do I find the part number for replacing control board for GE?
    WB27T10290
    I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
    Jun 02, 2010 | GE Profile JTP56 Electric Double Oven
    How do you unlock the door to a convection oven?
    Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
    Nov 18, 2009 | Kenmore Ovens
    Kitchenaid gas/convection stove oven door locked & won't open
    F5 - E7 Self clean latch will not unlock
    Remedy:
    1. If door latched:
    1. Disconnect power from unit.
    2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
    3. Replace door switch.
    4. Re-apply power.
    5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    2. If door not latched:
    2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
    3. Repeat steps A and B for door switch.
    3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
    4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
    5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    6. If failure remains, disconnect power and replace control.
    Note: Applies to all F5-E... codes.
    Sep 17, 2009 | Ovens
    My oven door lock is in the out position. Oven door won't shut
    Try shutting off circuit breaker for a few minutes to let control module to power down, then turn breaker back on. This may reset the control board back to factory default and retract the lock servo. If this doesn't work then a service tech will be needed.
    Aug 01, 2009 | GE Profile JTP56 Electric Double Oven
    After selfcleaning my electrical range Kenmore the door still loc
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jun 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    62 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
