Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Red blog and bubble vision, after lamp change.
After changing the lamp, Tv would not reset/ come back on. Temp light kept blinking. Day late, gave it a try and the TV came on note, temp in the room was alittle cooler. Now there is the red blog in the middle of the screen, and bubble vision between the colors on the screen. Is there an adjustmnet for the bubble vision? Is the red blog due to the light engine starting to fail?
    Problem Solver:
  • 8 Answers
YES, CHECK WITH HITACHI THEY ARE REPLACING SOME OUT OF WARRANTY LIGHT ENGINES
Posted on Dec 14, 2008
TV blue light comes on, then the red light blinks two times, on the 3rd blink, it goes into rapid blinking. I replaced the lamp and it worked for a week, but then the same issue. I put the old lamp back...
some units require a lamp counter reset.the ballast usually starts at extreme output and at certain hour interval the ballast would start to decrease voltage as the bulb ages.to reset on some models can be reset using the remote
Aug 12, 2013 | JVC HD-61Z786 61" Rear Projection HDTV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv turns for a couple of minutes then truns off by itself...the red light blinks on and the green light that say timer and lamp also blink...help how do i fix it?
The projection lamp on this tv,when was it was last change?The last time change was about 1 1/2 or 2 years,and tv on an used at 4 or 5 hours a day.The lamp life is over,require a new projection lamp.
Jul 10, 2010 | Akai PT61DL34 Television
TV stopped working. Power light is blue, temp and
How long has it been sense you changed the lamp? This type of symptom seem as if it could be the lamp needs replaced. Check the manual for the lamp number. Make sure you buy an original hitachi lamp. I assume this is the brand. Hope this is helpful.
Oct 28, 2009 | Hitachi Televison & Video
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
199 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
