Question about Motorola Mobility RAZR V3
My power button is broken is there a way i can still turn it on?
I think that the red power button on my samsung blast is broken and i was wondering if there was a nother way i could turn my phone on?
  • Anonymous Mar 25, 2009
    My power button won't work, so my phone won't turn on. Whenever I charge it, i can press any button, and the screen will light up. But when I push the power button, the screen doesn't light up. I need help !
  • smillieygurl Apr 04, 2009
    my end button is broke and i cant turn on my fone
    Brigadier General:
  • 7,752 Answers
You will need to take the phone to a mobile repair center and have them repair it for you
Posted on Dec 28, 2008
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Apr 30, 2014 | Samsung ML 2010 Laser Printer
When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
Dec 18, 2010 | Samsung ML 2010 Laser Printer
Can,t find my serial number
Is it a Samsung cell phone?If yes, then:
1. Turn off your cell phone. Press and hold your phone's power button for several seconds until the device shuts off.
2. Turn off your cell phone. Press and hold your phone's power button for several seconds until the device shuts off.
3. Remove the battery. Gently lift up on your phone's battery and remove it from the main compartment.
4. Locate the sticker on the bottom of the battery compartment. This sticker contains your device's serial number (also known as the IMEI or ESN number), along with other information about your phone.
Thank you and good luck!
Jun 20, 2010 | Samsung Blast Cellular Phone
Need to turn phone on but the power button is broke. It charges and turns on but just the charging screen
you need to replace the power button so that you can power your phone well again.
But there is another way by which you can power the phone without the power switch. This will involve you opening the phone cover so that you can gain access to the power button area on the phone board/panel.
Get a phone screw driver, open the phone, insert the battery into the phone, get a tiny wire and bridge the power switch panel and the phone will power on.
Try this, and it will work. I am very sure about this.
Take care.
Mar 18, 2010 | Samsung Blast Cellular Phone
The screen on my phone turned white
you drop it or get it wet?
try this:
with the phone powered on hold the send button down and remove the battery wait 3 min. put battery back in
Sep 29, 2009 | Samsung Blast Cellular Phone
Samsung Blast Power Button No longer Works.
that happened to me after i dropped it in the toilet. if you pry up the keys around it aswell as the power key because they are all connected and push really hard on the silver thing it will turn on. then just push the keys back in place. trust me it works!
Jul 13, 2009 | Samsung Blast Cellular Phone
Have samsung blast - lcd screen is broken - would i need to replace screen or the whole slidey thing
if you can turn on and off the phone than yes. is the screen cracked? if not then it's prob the flex cable. inside the phone.
Oct 13, 2008 | Samsung Cell Phones
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Phone wont turn on
Bring your phone to a technician to replace your power switch. I think that's the only problem... Good luck... ^_^
Sep 15, 2007 | Samsung SGH-D600 Cellular Phone
Motorola Mobility RAZR V3 Logo
526 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
