Question about Hitachi 43UWX10B 43" Rear Projection Television
Interference on BBC channels on my new Samsung LE32A457C1DX
Can anyone advise / help.
We have a Sony Bravia LCD which was in our living room, it was connected to the DVD and Video and works with no interference at all, just bought a 32" Samsung and put this in place and moved the Sony TV to the Kitchen, the Sony still works perfectly well with no interference but the Samsung pixelates for a short period and goes blank now and again, the annoying problem is that it only happens on the Digital setting and only with all the BBC channels all the rest are perfect. I live on the Isle of Arran, we have a standard attic aerial and have never had this before, i have bought 2 new scart leads but this has not made any difference, i have unplugged the TV and put it into another socket but still the same. I am baffled so any helpful hints or advice would be welcome.
Russell
techman
  • 3130 Answers
SOURCE: Color Issue
If the set is working on the video inputs, then it has be be an issue with the input source or the tuner or tuner control circuit in the set. If it was a bad lamp or a spark gap problems you would see a problem no matter what you hooked up to the set.
Posted on Dec 29, 2006
SOURCE: Large Black Box Showing up in middle of screen.
Thanks for the help! This ended a lot of frustration
Posted on Aug 23, 2007
  • 1153 Answers
SOURCE: Hitachi TV pixelating
Try to contact Hitachi on pixelating, I think there is a form that has to be filled out. I think they are aware of this problem.
Posted on Dec 27, 2007
IB4G2008
  • 3587 Answers
SOURCE: S video displays, but Component video is intermittant
Shall we assume that the DVD is fine, before addressing the TV issues? Does it work with any other device or component? Seems that if your S Video is clean, then it's just a matter of refining whether your DVD is as well. Check that, and let us know.
Posted on Feb 12, 2008
The Machine
  • 788 Answers
Check the options meny of your DVD player, there might be some settings for configuring the component output. I would also see of this is happening for all component devices (borrow an Xbox 360 or another DVD player), if it does that it may be a problem with your TV.
My mother has a cheap DVD player and when it is connected by component to there brand new Sony LCD TV the picture is tinted pink, I have determined that it is the DVD player that is causing the problem so they are sticking to S-video until they get a new DVD player.
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
Can only get bbc channels
http://www.retrevo.com/ 2670908141.pdf is the manual. See pg 20 Menus or T.S. pg 39.
Apr 30, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Sony Bravia that was bought in the UK, I now live in Ireland and brought the tvwith me, however when I conect to my antenna, I cannot find any irish terestrial tv channels, all I seem to pick up...
Most broadcasters have gone over to digital service and you may need an outside antenna to improve reception. Even a piece of wire would help but a proper antenna is best.... Cheers!
Feb 14, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
After BBC 1/2 switchover unable to retune these channels.Have Sony bravia KDL32S2510. Help!!!
do a default settings / factory reset if poss rather than a standard retune. After that watch out for too much signal..ie a booster and bypass it if you can.
Nov 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia kdl-46x2000 have lost channell 7 how do I get it back
We phoned Sony direct who advised us on how to fix the problem
Nov 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My new tv only gets some channels and not others
Have you tried an amplified antenna? It's basically a regular antenna but includes an amplifier to help bring in weak stations. An out door antenna may also help. I live about 3 miles from a TV station and can't pick them up due to the insanely old apartment I live in.
Jun 03, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
NO SOUND ON NEW TV
What kind of Connection do you have coming from the Dish receiver to Your New Sony Bravia TV. This is very important information.
Best regards
CircuitCity
Dec 05, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Hitachi 43UWX10B 43" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
