Question about DCS DW-24-SS Built-in Dishwasher
All all water inlet valves created equal :)
I'm having a problem locating a replacement OEM water inlet valve for my DCS dishwasher (DW-24SS). DCS customer service isn't much help, only answer I get is that's an older model we no longer have parts for it.
I figure these valves all basically do the same thing, so can I just get any ol' water inlet valve?
Thanks in advance!
  • 1,543 Answers
The short answer is no, all dishwasher valves are not the same. Newer dishwashers use much less water than older ones, and the valves are often ones which allow a lower flow rate (just like newer shower heads with low flow rates to conserve water) so that the timed fill cycle lets in a smaller amount of water. I do not have parts info for DCS, but this is what I would try: Units old enough to have discontinued parts probably did use basically the same water valves back then. Try a GE valve # WD15X93. The mounting may have to be modified, but you could even let the valve hang without mounting it to the dishwasher. (won't hurt a thing) Please don't bother rating this, as anything other than a FixYa will lower my score. Thanks.
Posted on Dec 12, 2008
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
Dishes on lower rack are not getting very clean, the soap dispenser on the door still has a lot of soap left in it. By soap I mean "Gel Dishwasher Detergent".
Check the water intake screen for sediment. Sometimes if sediment partially clogs the screen, the water pressure is lowered significantly enough to cause these conditions.
If you send me the make & model of your DW I'll tell you where the intake screen is. Sometimes its on the bottom which is a pain because you have to pull the DW out of the cabinetry...
Oct 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Inlet valve wont let the water in
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Aug 16, 2009 | Dishwashers
Dishwasher tub will not fill with water
Water-inlet valve
Float switch
May 24, 2009 | Dishwashers
I have a Maytag dishwasher model DWU8860 and it doesn't always fill after a pumpout cycle
It is probably a faulty inlet valve. Check the float switch first.
See here how to locate the parts.
See also this advice for repairclininc:
" There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Sep 06, 2008 | Maytag Dishwashers
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Need help with GE triton
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
Oct 07, 2006 | GE 24 in. GSD6660GSS Built-in Dishwasher
DCS DW-24-SS Built-in Dishwasher Logo
130 people viewed this question
Top DCS Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a DCS Dishwasher Expert? Answer questions, earn points and help others
