Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
Dishwasher repair In what order do the grinder blade and washer go on the shaft? Should the tabs on the grinder blade face away or toward me?
    President:
  • 878 Answers
Newbury, it should almost be flush to the screen, like a foward S. The inlet housing (protecter)will secure it in place. Catriver..post back
Posted on Mar 21, 2007
How do I mount the blade on Dewalt 7739? There is a distance piece, two cupped spacers, a nylon washer and a "washer" to change the blade diameter to fit the shaft. The shaft being small and the hole
Did you get a manual with it? If not go to www.manualslib.com and download one for a few bucks. The diameter spacer will likely go inside the blade ID and the cup washers facing cup inwards toward the blade, but without seeing it I can't say. See if there is a picture on "images" online.
Nov 15, 2014 | Washing Machines
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Which way does the jackshaft coupling go in a 95 herritage softail
The jackshaft must be installed back onto the starter shaft prior to installing the jackshaft with the shallow side of the coupling going/facing towards the jackshaft and also facingthe jackshaft splines. Remember to reinstall the coupling retaining ring if it was removed. ALSO, be sure to install the coupling on the starter output shaft with the counter bore facing the jackshaft. THEN put the spring inside the coupling and install the pinion gear on the shaft put the lockplate and the thrust washer on the bolt and put the bolt in place in the jackshaft. If you removed the retaining ring put it back on shaft and then slide the jackshaft assembly back into position in the inner primary. In order to hold the lockplate and thrust washer in place be certain that the lockplate tab is properly in the keyway. THEN, having aligned the lockplate tab and thrust washer properly in the slot with the jackshaft keyway screw the jackshaft bolt into the starter shaft and while holding the pinion gear in position tighten the bolt to 84-108 in-lbs (9.5-12.2 Nm) and bend the locking tab against bolt head.
Jun 22, 2014 | Harley Davidson FLSTC Heritage Softail...
Whitch way does the jackshaft coupling go
Jun 22, 2014 | 2000 Harley Davidson FLSTC Heritage...
How do you change the blade? I bought a new one but can't get the old one off. Thanks
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
Loose blade, motor still running blade not moving.
Its a fault with these machines. The blade is fixed on a plastic mounting (the black hemisphere you can see on top of the blade) and this seems to wear quite quickly. So the blade is not fixed to the shaft! To fix - you have to access the end of the motor shaft. To do this, pull the base out as far as it goes(15-20mm) insert a flat screwdriver into the barbed flaps on the central plastic shaft and push gently to release (not the easiest of jobs!) once released you should see the end of the motor shaft with a flat slot. Now, you can unscrew the capping nut holding the blade. I replaced the blade assembly with the following: First, 15mm OD washer with 4mm hole onto shaft. This should sit on the shaft at the bottom of the thread. Then the blade. You'll need a washer that sits into the hole in the blade to center it on the shaft. This washer needs to be slightly thinner that or the same thickness as the blade. Thesn another 15mm washer over this followed by a lock nut or cap nut to secure. This worked perfectly for me.
Oct 04, 2009 | Bodum 's C-MILL electric blade coffee...
ICE MAKER TAKEN APART -- IN WHAT ORDER DO I RE-ASSEMBLE IT?
Yeah I took mine apart and should have taken a picture of it before I did so. (Not too smart if I do say so.)
I'll put the steps here to assist, but here's a link to a small picture of it.
COMPLETE ASSEMBLY
The parts SHOULD go together in this order.
1. Start with wavy shaft standing on the plastic sleeve.
2. Slide the plate on the shaft.
3. Put the wheel on the plate so that it locks in place.
4. Put one of the rotating blades on the shaft so that it will cut in a clockwise direction. (as it is in the pic) Note that the rotating blades are offset slightly. I have no idea which order they go. Maybe first cut on the inside last cut on the outside. Dunno'.
5. Place one of the large nylon stepped washer with the 2 levels on the shaft with the smaller end facing up. (like the pic)
6. Remove the pin from the stationary blade holder as you will need one of those blades next. Remember how it was assembled or take a picture. :)
7. Place the stationary blade on the nylon spacer so that it will cut in a counter clockwise direction. (opposite to the direction of the pic above and toward the blade you already installed.)
8. Put a wavy washer on next.
9. Then put the angled plate thingy (I have nothing else to call it. It's called a damper in the link.) Place it on so that the edge is downward and the flat side it facing up. You want to place it like the picture on the left.
10. Another wavy washer.
11. Another one of the rotating blades in the same direction as the last one.
12. Place the other large nylon stepped washer on the shaft with the small end facing up like the last one.
13. Put the last stationary blade on in the same direction as the first one.
14. Another wavy washer.
15. Put the last angled plate thingy on in the same direction as the first one.
16. Another wavy washer.
17. The last rotating blade... Again in the same direction as the last 2.
18. Put the last washer with only one step on the shaft. (Looks like a top hat.)
19. FINALLY, put the lock washer on before you have a chance to knock it over and lose all the pieces :P
20. Put the blade anchor on the stationary blades in the same direction that you took it off. The pointier edge should be facing counter clockwise. You should only be able to slide the pin in place from the top. http://www.repairclinic.com/SSPartDetail.aspx?s=t-msd2351hew-%3d%3di375196&PartID=375196
21. I really hope that this helps someone. This thing is DAMN tricky to put back together. Make sure that the thing rotates easily by hand before sliding it back into your freezer. I expect that if something isn't quite right the motor will just bend the bar or other pieces. After all, it does crush ice!!!
Good luck.
Maggmah
Aug 06, 2009 | Maytag MSD2655HES Side by Side...
The blade has come loose
Had the same problem myself - another example of a product made to break!
Red Caboose has it spot on. Just a couple of points. The thread on the motor shaft is a 4mm machine screw. the shaft thickens a little bit below the thread (very short) forming a slight collar. I put a washer (slightly larger that the width of the blade) onto this, followed by the blade. You''ll then need a washer to sit into the blade to centre it on the shaft. Follow this with a cup washer (as Red Caboose) suggests or a locknut. Working perfectly now!
Aug 03, 2008 | Bodum 's C-MILL electric blade coffee...
Dishwasher repair
newbury, the screen should set in the grooves on the bottom. The chopper blade that fits on the shaft should have a small hub that fits over it. If you look on the housing cover (inlet protector) you will see a channel that slides over the end of the chopper blade shaft. This secures the chopper in place. Catriver.
Mar 06, 2007 | KitchenAid 24 in. KUDP01DL Built-in...
KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
94 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
