Question about Kenmore Elite HE4 Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top loading HE washer.  why would the dryer smell as if a fire took place in it? there are no marks inside and i have my vents/ducts cleaned professionally every single year.  could the motor have burned out in such a new machine????
  • willyheads Jan 12, 2009
    we have been doing laundry for over 2 years with no problems and tonight we went into the laundry room and it smells like a fire is happening in there. The vents have been cleaned, and there is no visible problems, but it still smells terrible.
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Posted on Jan 16, 2009
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore elite oasis dryer quiet pak 2 making loud screeching noises-
Either your glide pads that the front of the drum rides on are worn out, or the rear drum bearing are worn out
Mar 24, 2011 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
My dryer smells like burnned its an elite kenmore oasis and it doesnt dry very good
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Just inherited a kenmore elite oasis dryer model 110 77092600 Where can I get a user manual? Could be online. I called Sears and they want $18 to order one!!! Kenmore charges also.
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
286 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
