Question about Nautica Nst Chrono N19509g Watch for Men
Removing the pins in order to size a watch
How do i remove the pins?You can see the pins on the sides only. Its a Nautica steel watch. Im not sure if this is the number of the watch13533G.
    Problem Solver:
  • 17 Answers
Push the pins in with a very small tools they should contract and teh piece will pop off
Posted on Dec 12, 2008
How do you remove the back of my nautica watch to replace battery
Take your Nautica watch to a jeweler for a demonstration of how to remove the back. You might be able to persuade the jeweler to install a replacement battery.
Dec 13, 2017 | Nautica Watches
Nautica service centers philippines
Hello Fixya!
I have a problem with my Nautica watch bracelet steel. The pins are already broken most of the time and I want to replace for a new one.
Dec 17, 2013 | Nautica Watches
What tools do i need to repair the band on my nautica steel 10071G watch?
Sep 19, 2011 | Nautica N07518L Wrist Watch
What its a number to battery for nautica watch n09530?
Best way to make sure you buy the correct battery is to open the back and check the # on the battery. You may need a magnifier to see the # clearly. If your changing it yourself be sure to use a blunt, non-metallic tool to remove and replace the battery.
Mar 08, 2011 | Nautica N09530 Watch for Men
How do I remove watch band links from m Stainless Steel Nautica Watch? Model #A45001G
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well.
May 21, 2010 | Nautica Blue Dail Yacht Chronograph Watch...
How do i remove a link from a Nautica Mens A35092m? It has larger looking screws on the sides of the links, but i can not get them to budge
If these are screws you have to use two screwdrivers simultaneously - one from each side. Try to unscrew one screw and see if the other screw on other side is moving alongside. If it does - definitely use two screwdrivers.
Jan 29, 2010 | Nautica N07518L Wrist Watch
How to remove watchband links from an Invicta watch
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Oct 20, 2009 | Lucien Piccard 26024 Wrist Watch
Trying to push out pins in watch link with no arrows,
Anne Klein can be difficult to size. I recommend taking this to a jewelry store for sizing.
If you are set on doing it yourself then this should help. Use some good quality penetrating oil on the pins (both sides) and let sit over night. Then it's going to take a hammer, vise, and appropriatly sized pin pusher or steel rod. Hope this helps
Apr 04, 2009 | Citizen Eco-Drive Silhouette EW869452D...
How to adjust watch band on relic steel watch
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Dec 26, 2008 | Watches
Watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Oct 31, 2006 | Nautica N07518L Wrist Watch
Nautica Nst Chrono N19509g Watch for Men Logo
142 people viewed this question
Top Nautica Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Nautica Watch Expert? Answer questions, earn points and help others
