Code 42-1 Sorry, what I meant is I'm seeing code 42-1 on my konica 3135 copier. Can you tell me what's up?
  • Anonymous Feb 01, 2009
    Can you give me some type of price range when it comes to repairing it?
  • 42 Answers
This is a lens drive problem.Turn on the copier and look under platen glass where you lay your originals to see if the len is moving.It should cycle back and forth when copier is powered up.If it does not,the lens drive motor has a cracked drive gear.Seen this many times!
Posted on Dec 11, 2008
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Error message 45-1 is being display on Konica Copier model 3135
most often what i have seen the cause of this problem is the lens motor pulley gets a crack in it which causes the pulley not to turn when the motor turns i have had some luck with pulling the pulley off the shaft and putting a drop of super glue on it then put it back on the shaft and it will hold for a while but the bad news is they dont make parts for this machine anymore so the time is near for this machine to be replaced sorry
Nov 27, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Jun 26, 2008 | Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
66 people viewed this question
jasbo
jasbo
