Question about Canon LaserClass 2060P Plain Paper Fax
Paper tray is jammed, it won't come out.
How can I remove it to refill?
  • hrdac05-bloc Feb 26, 2009
    paper tray is jammed on canon 2060 P. Tried turning off and on.
    Tray still will not remove. If you look inside there is a black metal part caught in one of the openings of the tray
  • 4 Answers
With the paper tray pushed all the way in, try unplugging the machine ... try to remove the tray. If that doesn't work, then plug it back in ... try to remove the tray.
If neither of these allows you to remove the tray, you may have a broken part.
Posted on Dec 19, 2008
My Epson 3620 printer keeps telling me a have a paper jam. I cannot find one!
Hi, Try the following: remove paper feed tray completely, , remove paper, restack and refill, check and make sure there is no paper stuck from where the feeding tray is positioned. Then re install paper tray, make sure it is position correctly. Open and close all the places you did open and close to inspect for paper jam, make sure they are close securely as to activate the microswitches. switch machine off and restart. Hope this works
Dec 04, 2017 | Epson Office Equipment & Supplies
Paper jam
  1. Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Remove the cover from the housing of your Lexmark printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Unplug your Lexmark printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Plug the printer back in, refill the paper tray and try to print again.
Thank you.
Oct 30, 2012 | IBM Office Equipment & Supplies
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
Gently pull on the jammed paper. In many cases, it will come out easily.
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Printer say's paper jam, but no paper is in it
The paper is not jammed in the tray, it is jammed inside of the printer itself. Open the printer until you can see where the roller is (that is where the paper gets feed through the printer) and that is probably where you will find the jam. Gently tug on the paper, wiggling it back and forth until it is removed, then refill the paper tray, and test. Good luck and I hope this helps.
Oct 27, 2009 | Canon Office Equipment & Supplies
How can fix the jammed paper situation?
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Input tray jammed/locked
The input paper tray is removeable. So try the link below to try to get your all in one machine set up  again.
Jan 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
Look for a "jam door" at the rear of your printer (if so equipped).
You will need : 1 can of "compressed air", 1 container of ether rubbing alcohol or some form of Goo-Gone.
1. In short blasts (NOT LONG ONES) blow through the paper path. Open any paper jam access trays before doing this so the bits escape.
2. Using a SMALL amount of Goo-Gone and either a Q-Tip or small dust free cloth, clean all the rubber rollers on the bars. Cheap paper leaves a fine dust and after time will make the wheels very slick.
Doing this every other month can save you from jams and is just a good maintenance plan for your printer.
Also don't use 'cheap paper'.
Good luck! :)
Dec 02, 2008 | HP LaserJet 1300 Printer
Canon LaserClass 2060P Plain Paper Fax Logo
95 people viewed this question
old marine
old marine
