Question about Biostar M7VIZ Motherboard
Power won't turn off and computer will not boot. I've removed the battery and cleared the CMOS with the jumper. lt happened after a couple of power failures at home however pwer supply has a surge protector. When I insert the power cable, power and rest lights are on in case, all fans are running but I notice that only one LED on the motherboard is illuminated. no error beeps or boot up This generic PC was running okay but now, on power up, I get a one second beep, followed by a five second pause, repeated indefinitely. No monitor, no keyboard LEDs and it won't power down. According to everything that I've read this is not a BIOS error code. The mobo manual doesn't mention any audio error codes in troubleshooting. I've swapped out the power supply and reseated the RAM. Where do I go from here? thanks, Bob
If i understand you correctly, you are saying that you have a single beep repeating over and over with nothing showing on the monitor and no other response from your computer? The single long beep in a loop is an Award Bios beep code for a faulty CPU. This problem is not mentioned on the official website of the manufacturer. Unfortunately your only option is to replace the CPU. You might try removing and re-seating the cpu making sure you have proper cooling measures in place. Hope that helps!
Posted on Dec 12, 2008
How to remove bios password of compaq armda 1700
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Although on some motherboards the Cmos battery is soldered in
if you have no joy
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of tenhope it helps
May 10, 2012 | Compaq Computers & Internet
Acer aspire one kav60 restore asking for a password.
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
if still no luck
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten hope it helps
Apr 27, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE KAV60 AOD250-1198 RESTORE AND NO PASSWORD
or if using XP
if still no luck
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Apr 27, 2012 | Acer Aspire One PC Notebook
Bios boot password on a Toshiba c655-s5049
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Feb 25, 2011 | Toshiba Computers & Internet
How to break the bios password?
All you need to do is just to power off your system, remove the battery and unscrew all the screws that will lead you to your board.
When you are at the board, remove the cmos battery of your laptop and put back your laptop battery to power on the laptop for a while, power on without the cmos battery, your laptop will be reset and will not ask of the bios password anymore.
After it has been reset, you can now put back the cmos battery and couple everything back.
Your laptop will work without asking you bios password anymore.
Take care
Apr 20, 2010 | Apple MacBook Pro PC Notebook
I forgot my acer lab top's password, how do i find it?
There are very ways to clear the bios password to access your computer but lets try a couple that I know about. Your laptop does not have pins and a jumper block but instead it has a small area known as a jumper pad. This pad is directly under the memory modules on the motherboard and is known as J3 which is printed on the motherboard. The jumper is small and what needs to happen is you have to "short" the jumper with two small pins shile powering the laptop up and letting it boot. Once the boot process completes, power down the laptop, remove the jumper and the password and cmos will be clear. replace the memory and reboot, you will have to get back into the bios to reset the time and date.
The other way is to remove the cmos battery or RTC battery for about an hour, this may reset the cmos also but it is not as effective as shorting out the jumper pad which is what that pad is for.
Dec 26, 2009 | Acer Aspire 3690-2196 Notebook
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Jun 11, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
Will not power-up after a shut down unless the CMOS is cleared.
try swapping the Ram Chips "Memory" try running it with less memory or if you have multi chips take a few out and run it
Good luck
Please rate US! thanks
Jul 14, 2008 | ASUS P4P800-MX Motherboard
Biostar M7VIZ Motherboard Logo
204 people viewed this question
Top Biostar Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
