Question about HP f2105 21" LCD Monitor
Thin blue vertical line on display of hp pavillion dv6000 laptop
I don't think it is related, but cursor is also unresponsive after boot | running Vista, but can wipe it and load XP pro if necessary.
SOURCE: thin blue line
vertical line on my hp f2105, at first there was 2 on the left after 2 month another one came up in the middle and after 5 month onother one again came up on the right. this is a good monitor when it comes to design and picture but durability.... it is a failure.
Posted on Jan 19, 2008
SOURCE: Unable to install Windows XP on HP Pavillion DV2000 ( Built in Vista )
Best Solution is to disable Native SATA support in BIOS ,
Now Win XP will recognize the Hard Disk
Posted on Jul 13, 2008
Papirin
  • 8 Answers
SOURCE: Vertical lines in my laptop screen
Try using an external monitor,every laptop has a blue VGA connector,just connect a monitor there and check is those lines
disappear,if it does,probably you have a problem with the internal connection of your monitor to the motherboard.
Posted on Sep 07, 2008
antiochpc
  • 1314 Answers
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Posted on Dec 26, 2008
SOURCE: HP Pavillion zd8000 lines on monitor
To date, HP has refused to repair these defective laptops despite being fully aware that the problems do exist. The only real solution that I'm aware of is to write to the BBB (the one in California located near HP's Executive Offices). HP agreed to repair my laptop at no charge after I went this route. To the best of my knowledge, they replaced the display as I no longer have the vertical lines. It appears that they may have also reduced the processor speed as the computer runs much cooler than it ever did before HP made the repair. It's been several months since the repair was made and, so far, no problems whatsoever. Hopefully that will continue.
Posted on Dec 31, 2008
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
David
May 27, 2013 | HP Pavilion Computers & Internet
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have a HP Pavillion Media Center PC model m8047c. When I power up, it starts to boot up then i get a blue screen with vertical white lines and thats as far as it goes.
This may due to improper display drivers or corrupted display drivers Download and install latest display driver will resolve your problem.
Revert back for more assistance.
Jan 20, 2010 | Computers & Internet
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Line on the screen
I have a black vertical line about 3/4" wide with thin border pink, green and blue lines. My cursor runs behind this line but I am unable to find a way to make it just go away?
May 09, 2009 | Computers & Internet
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sep 07, 2008 | HP Pavilion dv6000z Notebook
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
HP f2105 21" LCD Monitor Logo
205 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
