Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Need to Reformat my Western Digital 500 Gig Hardrive
I am a mac user but need to send a lot of digital images to a company that only uses PC. Currently the Hard Drive is formatted for Macintosh.
How do I reformat the Hard Drive so both Macintosh and PC computers can read and write to it.
You want to make the drive FAT32. Both Mac and PC can read and write to FAT32 drives. Macs cannot write to NTFS drives, but they can read from them. Many external hard drives come preformatted as FAT32 for this reason, so users can do exactly what you're trying to do.
FAT32 was the prevalent drive format in the PC world for several years. FAT32 drives are somewhat less stable/more prone to errors than newer formats like NTFS, but if you take care of the drive, you should not have any trouble.
Posted on Dec 27, 2008
    Scholar:
  • 113 Answers
Simple, you have to format it by selecting Dos Drive which supports NTFS format.  or else try other option which is to format it in PC computer be sure you will select the NTFS format not FAT32. Im sure you can use it now to both Mac and PC.
Posted on Dec 14, 2008
    Novelist:
    Champion:
  • 233 Answers
You don't really need to do anything. Today both Macs and PCs recognize all common PDFs. So if you are just swapping files back and forth you should have no problems.
Posted on Dec 22, 2008
4 Suggested Answers
tonybudz
  • 162 Answers
SOURCE: format harddrvies western digital wd1600
try using the dynamic drive overlay supplied with the drive? Your MB may not be able to handle it.
Posted on Aug 12, 2008
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
Mattkintosh
SOURCE: Western Digital Hard Drive will no longer mount
HI. So I had this problem twice with the same hard drive. I didn't have the money to replace the hard drive the first time, but this time I did, so my ultimate solution to offer is to purchase a different HD and migrate the data from the current one.
How did I get the drive to turn back on so I could get the data migrated to the new HD? Persistence! I kept disconnecting and reconnecting the drive, making sure to shut the drive down by pressing the blue button on the front until the drive powered down. I disconnected, waited for some time (between ten and 20 minutes) Then I reconnected the FireWire cable first, and the power cable second, waited for it to mount - and eventually...
IT DID!!
Wow am I happy. I'm going to run a series of diagnostics on this one but I'm probably going to retire it. Too bad because 500 gigs is a lot of space to loose, but this being the second occurrence makes parting all the easier. I mean, my entire iTunes library is on this thing!
So, just keep trying - plug the drive into the computer, then connect the power cable and wait for it to come on.
I'm running Mac OS 10.6.4 and an older machine 10.4.11, both of which were able to read this drive before, the 10.6.4 had the problem initially, then both machines had issues. Ultimately the 10.6 machine was successful with a FireWire 400 connection.
I hope this helps!!
Posted on Oct 19, 2010
We had a PC that we were using with our drive. The PC died and we just purchased a Mac. When the drive is plugged into the Mac it doesn't show there are any files. What am I doing wrong?
The drive is most likely formatted NTFS. You will need ti install software on your mac such as NTFS-3G to enable you to read and write to the drive. If you need to use this drive for PC and Mac you will to copy all your files to your computer and then reformat it FAT using Disk Utility. Remember to copy all your data from the drive before formatting as it will ease it.
Jan 30, 2011 | Western Digital My Passport Essential...
1 TB External drive, unable to open (data of 80% is there)
You can't format without loosing data. You should get a professional data recovery company to look at the drive. http://techrxgb.com is my recommendation.
Jun 01, 2010 | Western Digital My Book Home Edition 500...
I have a 500GB my book essential edition external harddrive and i am only able to access 10GB of my space, please help
while you only have 10 gig of space "used?" take what you have off the drive and use the disk that came with your WD MYBook and reformat the drive into "2" drives..........Depending what OS (operating software) you are using some have a limitation to show the correct amount this is why I would suggest that you split the drive into sections or just reformat and see what you get
Jan 26, 2010 | Western Digital My Book Essential Edition...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Reformat for a mac
put they installition disk that came with your mac. reboot your system then hold C. then you can format your mac.
Jul 15, 2009 | Western Digital My Book Essential Edition...
Western digital 500 home, is it mac compatible
My mac reads it and I can work from it, but it's much slower than on my PC
Apr 01, 2009 | Western Digital My Book Essential Edition...
Wont read ext hard drive...says bad sectors...
Have you tried goggling for data recovery software. There are a lot of free ones if you had that to your search. But, I've used several paid for ones that worked. I'd try to trail versions to download and first see if can read the drive. If it can't the next thing I would do, is to dismantle the case around the hard drive, and take out the physical hard drive and switch the back pins to Slave, and add it to your computer. (make sure you have your main drive as Master) Then as a slave drive you have a lot more options to recover data.
Good Luck
Mark
Feb 23, 2009 | Western Digital My Book Essential 500GB...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
2,137 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
