Question about Panasonic Microwave Ovens
Damaged internal door panel
I have burnt the internal panel on the door of my panasonic microwave oven. The outer panel is ok can I replace it or do I need to replace the whole door
  • Panasonic Master
  • 9,086 Answers
For most models, door panel parts are available and can be replaced separately.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
Posted on Dec 13, 2008
I have to slam the door 5 times to get it to turn on
Have you tried leaving it after GENTLY closing the door once? Many have a timer so that the fan can remove condensation from the inside. If that doesn't work, you need to take it to the nearest Panasonic service centre to have the door microswitch adjusted or replaced. There are no self serviceable options with microwave ovens due to the disastrous damage operating one without the outer case can cause. The use special screws only the tech carry.
At least you have a good make, so worth having it fixed. I used Panasonic ovens in a restaurant setting.
Sep 19, 2015 | Panasonic Genius Prestige Inverter...
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
Sep 30, 2014 | Panasonic NN-H965 Microwave Oven
What do i do about the tirntable not turning
first open door an take a good sniff see if you smell any burnt smell it could be a burnt out drive motor or a broken wire there are repair shops that do that DO NOT TRY AND FIX YOUR SELF read the warning panel
Jul 11, 2014 | Panasonic NN-H965 Microwave Oven
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Nov 20, 2011 | Panasonic NN-H275 Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
My Panasonic nn-s262 microwave/fan keeps reseting every time I try to use the microwave. The fan works fine and the light worked fine until today, it now resets the microwave. What can it be?
internal short that can damage your control panel but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 30, 2009 | Panasonic NN-S262SF Microwave Oven
Microwave blows the fuse when you push the start button on the panel
This will be either a faulty door interlock switch or High voltage component. You will need to remove the outer cover after first disconnecting power. Discharge the high voltage capactitor!
Check the door switches are operating correctly if so move on to the high voltage components starting with the transformer
Dec 28, 2009 | Panasonic NN-P295SF Microwave Oven
Whirlpool microwave model MH1150XMS-0 is not working
your door monitor switch has gone out. they are 3 switch that monitor the door. remove control panel. they are located behind frame where the door clips go into.
Jun 24, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
111 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
