Question about GE 24 in. GSD4320Z Built-in Dishwasher
Error code: "Ih" on GE Triton XL. What is reset combo?
Just after pushing start, I decided to open the dishwasher and add another glass. After shutting, would not start again and had an error code of "Ih" in the information window. Is there a reset code?
  • 1 more comment
  • David Winder Dec 15, 2008
    I provided the solution to my own problem. Thanks, DW
  • g_sheridan Dec 15, 2008
    After starting my dishwasher I turned it off and it seems to have put it into a reset cycle of sorts? Two lights on the front are flashing and it's running but no water or washing is happening. How do I correct this?
  • amymjjk Dec 25, 2008
    I have a few lights showing at once and it will not start.  When I push a different button, two other lights go on and it still will not start.  How can I reset the dishwasher?
After leaving the dishwasher locked with the error code still showing, I returned to find that it had reset itself and run through the full cycle.
Problem solved itself.
Posted on Dec 12, 2008
  • dgbiggs Sep 22, 2010
    IH is actully 1h, or 1 hour on the delay to start the wash. Just keep pressing the delay until it clears (after 24hrs) and the washer will start.
A GE dishwasher GDT580 that's displaying code 1H or IH and will not start
that's not an error code. it's a 1H, as in one hour, the delayed start function. hold the delay start button down to override, then reset it back to where you want it.
Aug 27, 2015 | GE GDT580SSFSS 24" Stainless Steel...
My GE Triton XL is not working. When you push start the "sensing" and "washing" lights come on, and it fills with water. The element heats the water, but then the cycle seems to end. ...
Hi Michael,
It seems one of the components aren't doing its part in continuing the cycle. Does your machine physically pump out water?
Please confirm for me, then I will reply.
Regards
JEDEMEYER1
Jul 25, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
The control panel of our GE Triton is not working. Is there a reset button?
Triton is usually trouble-free, however there is no reset button. Depending on the model and series, there may be a code (that is: a combination of panel buttons to push that will bring the control to a zero entry level (also known as default level). This would be in the owners manual under trouble shooting or problem with the appliance.
The other option that works many times is: disconnect power to the unit for 2 minutes. This will help the control to start its logic from the beginning. Then turn power on and try the machine; this will tell you if the control now responds. IF NOT , you have an 80% chance that a new control panel is needed. Welcome to the wonderful world of electronics. Its great when all is working, but ohhhh so tempermental.
Goodluck, Macgivor
Oct 24, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE TRITON XL REPLACEMENT SOAP DISPENSER?
Best way is to call GE Part at 1-800-626-2002 or go online to www.geappliances.com
Dec 20, 2008 | Dishwashers
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton XL Dishwasher
My Triton XL soap dispenser still has a clump of soap after the cycle has finished. My glasses are left with a cloudy film, and my silverware is left marked with film on it. I have cut down on the amount of detergent, and have not overfilled. I have also tried using white vinegar as the manual states. Any suggestions? Thank you
Aug 17, 2008 | Dishwashers
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Open Questions:
See all GE 24 in. GSD4320Z Built-in Dishwasher Questions
GE 24 in. GSD4320Z Built-in Dishwasher Logo
3,239 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
