Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 My printer after nearly two years of reasonable usage has decided to go slow. It now takes about 10 minutes to print one page. I spke to hp yesterday and they charged me £12 for a 24 minute phone call to tell me to buy a new printer. It does however print just very very slowly Any Ideas the Mediator
Did you fix this issue ?
my 6210 behaves in the exact same manner after 2 years of use
maybe that't their life span !
i'm now printing a page, it's half way and it took 10 min to get there
if you fixed this issue please let me know.
Posted on Sep 07, 2008
  • 944 Answers
Here is the link to all the support options for your printer including user manual and troubleshooting if you need it; http://h10025.www1.hp.com/ewfrf/wc/product?product=421991&lc=en&cc=uk&dlc=en&lang=en&cc=uk first follow this troubleshooting procedure if you have a windows pc connected; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en and this one for Mac; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00108051&lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en Hopefully this will resolve the issue, especially the third item about turning off the paper type sensor. any help you need with any of the procedures, please ask again. If this doesn't work, then; Make sure your drivers are up to date and not corrupted - download new drivers from; http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=uk&dlc=en&product=421991&rule=36216&lang=en& see if you can borrow another printer from someone (doesn't have to be the same, but that would be best), install it and then see if you get the same problem, confirming if the data transfer from the pc is or is not the problem. If the other printer works fine, then the next thing to suspect would be the power supply - try plugging into a different power socket, and try and get hold of a new power adaptor and see if that works. Replace any connecting cables to the pc with new good ones, just in case that is the problem. Hope this helps, if the machine prints at all then it should be fixable :)
Posted on Mar 22, 2007
HP Officejet 4500 printing extremely slow
REMOVE ALL INK CARTRIDGEES, & CLEAN ALL CONTACTS,INSERT ALL CARTRIDGES, TRY AGAIN, BUT YOU SHULD CONFIRM ALL CARTRIDGE IS ORGINAL HP.
Apr 09, 2014 | HEWLETT-PACKARD Officejet 4500 All-in-One...
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Very slow printing on my HP office jet J 3680
you may need to visit the hp website for additional software
Apr 19, 2010 | HP J3680 Officejet All In One Printer
Hp 6210 all in one won't print. Neither the fax
Power off for one minute at least! Power on. self test should run. follow directions on LED screen of printer.
Nov 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
Printing very very slow 1 page about 10 minutes
go to your printer/print settings/preferences adjust your print options there. set your dry time to less. ink usage to less and /or change your print quality to fast normal or draft. in printerpreferences select spool to printer first.
Apr 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp 6210 Fax Problem
no this issue may occur if you line is noisy.You can also try to change the FAX SPEED to slow and the same time turn-off ERROR COrrection MODE.
- you can locate this options on the ADVANCE FAX SET_UP
Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Very slow printing
Try to make a photocopy first from the printer itself, if it can print faster then the problem is on the computer,if not then follow the steps below:
Clean the printheads, clean the nozzles, if it still print slowly, remove the cartridges and clean the nozzles. If these steps does not resolved the problem then try changing the cartridges, maybe there's something wrong with the cartridges itself. After changing the cartridges, try to print again, and if its still the same then just post it here and ill try to find another solution for you.
Jan 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
1,178 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
