Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki brute force 750 2005, idles fine, but when you press the throttle it backfires, is this due to a carb problem?
  • Anonymous Mar 22, 2014
    I have a 2009 kawasaki prairie 360 4x4 and it starts and idles fine and starts off fine about 1/4 throttle but when i push it any further it spits and sputters. if i put the choke on and nail it itll run perfect until i stop and it cuts off. i have cleaned the carb comepletely. can anyone help?
  • Anonymous Mar 29, 2014
    back firing when you
    give it it gas
Your jetting on the carbs are wrong.
if you want more info on the jetting and how to do it along with some GREAT info, check out highlifter.com/forum
Posted on Dec 18, 2008
I have a 05' brute force. It starts and idles great but when i drive it misses out and when i let off the gas it backfires. Any ideas why? I have cleaned the carbs and changed spark plugs
Do you have a multi-meter and can check your cdi? The cdi is known as an igniter. It's what actually sends the signal to the ignition coil to fire down to the plug. If you can test your cdi and let me know, I'll see if I can find the specs - also, are you able to check your timing?
Dec 25, 2015 | kawasaki 2005 Brute Force 750 4x4i
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
I have a 2005 brute 750. It will start and idle fine, but when you give it gas it begins to miss and backfire through the carbs and tail pipe. I just took the carbs off and cleaned the jets, new plugs and...
If it just crossed the 100hr mark the Check Belt function of the ECU will be activated. Perform the Belt Light Reset if is crossing a 100hr mark on the odo
Jan 20, 2018 | kawasaki 2005 Brute Force 750 4x4i
"06" Brute Force 750 back firing thru the carburators
Sounds like you may have to do a complete carburetor cleaning. Also, after this is done, be sure to put the breather box back and that includes the box cover. That bike is not worth a fiddlers, ..... without that cover put back on it. If the carburetor cleaning is not done properly then you'll still have the problem. Also, be careful when taking the carbs apart, they have different size jets in them and don't move anything in regards to linkages. Those carbs are also syncronized.
If that don't do it, then maybe, you'll need your valve clearances adjusted.
Good luck
Nov 01, 2009 | kawasaki Full Suspension Mountain Bike Men
05 750 brute force missing badly
Just had same problem. Take carbs off and clean all jets and bowl. Be carful front and rear carb have different sized jets. When you put quad back together put entire airbox together even the cover. This quad will backfire unless air box is complete. I bet you anything your carb is full of trash.
Jan 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Backfiring on kawasaki bruteforce 750 atv
yes,
check the jetting on the carbs
there is some great info on highlifter.com/forum along with how to do it good luck!
Dec 11, 2008 | kawasaki Full Suspension Mountain Bike Men
good chance u have a bent rod, bent valve. Need to take to shop to get checked out.
Oct 30, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
1,068 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
