Question about Whirlpool GGQ8831L Gas Dryer
DRYER SHUTTING OFF BEFORE CLOTHES ARE DRY
WHIRLPOOL GGW9200LW0
HAVE HAD THERMISTOR REPLACED
WORKED FOR WHILE THEN STARTED AGAIN
CHECKED EXHAUST AND MADE MORE DIRECT RUN OF PIPING OUTSIDE
SCREEN CLEAN
REMOVED NEW THERMISTOR AND CLEANED
NO CHANGE
IS IT POSSIBLE FOR 2 THERMISTORS TO GO BAD??
  • cdietrich Dec 16, 2008
    thanks for the suggestion
    i have already taken off the exhaust pipe (metal flex) and cleaned and shortened. the outside exhaust cover works well with flaps opening quickly and completely. wall run is about 6 feet
    i ordered a third thermister and will replace. I am wondering if the electronic circuit board in the upper unit could cause this problem?? I also saw that there exist a thermal fuse --but I felt if that went --then absolutely no heat --i don't think fuses reset themselves
    so at present sometimes it dries completely --other times not
    despite change of setting on control panel
    frustrated
    anyone have any other ideas??
    chuck
  • Whirlpool Master
  • 8,220 Answers
What you obviously have is a blocked filter housing. Get it off and wash it down. Clean out the dryer and open the vent.
Posted on Dec 16, 2008
  • Dan Webster
    Dan Webster Dec 16, 2008
    The filter housing inside the machine is blocked. No amount of thermisters is gonna fix your problem. You must tear down the machine and get the housing out, wash it down with a water hose.
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
Gas dryer does not dry in "timed Dry" setting
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Whirlpool dryer overheats, heats on air only
Sounds like heating element may be grounding out.
Oct 27, 2017 | Whirlpool Dryers
Dryer usually takes 2 or more cycles on High Heat to completely dry clothes.
check your exhaust vent for any obstructions if it is clear then your thermistor and thermostat are bad.
Dec 17, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
GGW9868KL0 SENSEON GAS DRYER Flame comes on but clothes not dry
since you know your stuff and our exhaust is clear correct,,,change your gas vavle coils ..if weak they will shut unit down in a couple of mintues..
Dec 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
216 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
