Question about Panasonic PT-47WX49 47" Rear Projection Television
Graphics are cut off.
No matter what I do with the convergence my picture is cutting graphics either on the top or the bottom or even the sides of the screen. I tried every aspect ratio and failed. For example, any bottomline wheather its news or espn, I cannot read the scroll entirely. If I were to bring the picture up a little, then I cut the graphics on the top. If I were to move the picture to the left, then it becomes tilted. Every other TV in my home doesnt have this problem. Can anyone help. Thank you.
  • Anthony Rotondo Mar 23, 2007
    its not on either side, it the bottom of the screen. the bottomlines on the news or espn are cut off. If I were to adjust the picture up, then the graphics on top of the screen get cut off.
  • 67 Answers
Sounds like a sustained board not really sure a picture would help is it just on one side?
Posted on Mar 21, 2007
2 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: Graphics are cut off.
First, have you made any adjustments to the tv other than from the setup menu? If not I have the service manuals for the tv in pdf files and would be glad to send them to you. Let me know I have the same tv and corrected the same problem. v/r, Scott
Posted on Mar 11, 2007
Graphics card fan wire
twine ,connect the wire you cut, and wrap it with electrical tape...
Apr 16, 2016 | ASUS Directcu Ii Top Geforce Gtx 560 Ti...
Do the graphics on the blade face up to the mower or down to the grass when fitting a new blade?
Many blade has grass side stamped into the metal.
You want the cutting to be on the leading edge either way; otherwords, the cutting sharp edge leading. Most blades also turn clockwise when viewed from the top and counter clockwise when viewed from the grass side
Apr 06, 2015 | Garden
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Picture on screen is cut off
reset the settings to factory default. if that does not clear it up, there is a sync issue. try a different cable. otherwise, there is a problem with the main board.
Jul 08, 2009 | InFocus LP 340B Multimedia Projector
My picture looks funny on all four sides.
its due to the faulty convergence. the stk convergence ic on the main board which controls the picture alignment is faulty and needs to be replaced to solve this problem.any tv technician will do it for you at a very negligible cost. nothing to worry.thanks.
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
Projected image is too large for screen
Good Day Brian;
The warped, too large picture is the same problem, the TV has a convergence problem. ln today's electronics the first thing that should be done on any electronic device is to, reset, unplug TV from the a/c outlet for at least 4-5 minutes then plug back in. If no fix; Your TV has a circuit problem. RCA has three common problems that could cause this condition; the most common is a fuse near the fly-back, IH-VT, the convergence power board or the signal board.
Always, call a factory authorized service dealer if you are not familiar with repairing electronic equipment that contain HIGH VOLTAGE, just for your own safety.
Good Luck, Big Irish.
Jun 21, 2008 | RCA Televison & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Toshiba cf27c30
Hi, you only have a setting problem. Go to "Click START, Control Panel,Then click "DISPLAY" When this window opens click settings on top RHS of window. Click "ADVANCED" At the top of this window there will be a dialog box with a setting in it and a drop down to choose another setting. select a setting lower than the one already showing. This will fix your problem. Regards Mistyman
Aug 07, 2007 | Jaton 3DForce4 MX440-8X-64TV (64 MB)...
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
233 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
