Question about Zanussi 24 in. DA6141 Built-in Dishwasher
Wont clean dishes
Hi , the top section of my dish washer , wont clean, we had a man out last year, who took out the section that spins round , it cleaned well for a while,but now it is given trouble again, does anybody know how to take the spinning arm out , our other dish washer , which we left in our last when we moved house never gave trouble , and we had for it for twelve years , this dish washer is only just over two years old , many thanks , joeboy.
  • 725 Answers
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Posted on Aug 15, 2007
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
- the dishes and glassware on the top rack are not coming out clean - I checked the course strainer to see if it is being blocked but don't see any thing there - I also took out the spray arm that sprays...
IF you take the racks out and look at the back you will see a tube that runs from the pump to the upper rack spray bar. The tube has TWO connections that the upperspray bar contacts but it only uses one of them. The other is closed off by a interior flap. If the flap comes loose, it wont allow enough pressure to the top spray bar. If the pump is plugged it wont build pressure either.
May 22, 2017 | KitchenAid 24 in. KUDI01DL - Multiple...
UPPER DISHES DONOT EVEN COME CLOSE TO CLEAN.TRIED REMOVING EVERYTHING BUT SEVERAL DISHES ON TOP, SPACED EVENLYSOME FACED UP SOME FACED DOWN NONE CAME CLEAN...Suspect not enough pressure going to the top...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 16, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
The top rack dishes do not get cleaned. I have run the vinegar rinse. The bottom rack dishes get cleaned. It doesn't even look like the top rack dishes get wet. I ran the washer without the top rack in and...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 06, 2010 | Dishwashers
After running our dishes through a wash cycle we noticed there was still a lot of food stuck on the plates & glasses etc. We cleaned out the trap but due to the murky water in the well, we also pulled...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top jet washer in my dish washer is not rotating and cleaning my dishes. The bottom is working well. I am just wanting to know what the problem might be.
heatman101
Oct 11, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
My dish washer is not washing the dishes on the top shelf and leaves a sand like residue on top of the cups and glasses. I have washed out the top spraying arm and washed the dish washer out with vinegar.
Dishwasher
How to Buy
heatman101
Oct 01, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishes on top shelf not cleaning
heatman101
4w56er
Mar 02, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Siemens dishwasher does not wsh the dishes
heatman101
eqrte
Jun 16, 2009 | Siemens 24 in. SL84A305UC Built-in...
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
321 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
