Question about Samsung CLP 300 Laser Printer
Hi there, I have a Samsung CLP-300 (color laser printer) and my smart guide menu is telling me that my fuser is having a heating issue. I've already talked with Samsung tech support and because I'm out of warrenty , I'm S.O.L... and I'm hoping to not have to shell out the $100 plus dollars to have it replaced at a shop. I'm pretty handy myself, I've taken t.v.s apart and fixed them; I'm just not sure on the anatomy of this particular machine and if I'm replaceing the fusing rod, what other parts do I need to replace (like when you do an oil change in a car, you generally replace the air filter too) Thanks for any help you can lend.
  • 97 Answers
As long as the rollers is not damadged, the only other part I would replace is the thermistor unit that senses the temperature. That shoul do it.
Posted on Sep 13, 2009
    Champion:
  • 220 Answers
Lamp,heat sensor,roller and gears.
Posted on Jul 03, 2009
4 Suggested Answers
  • 670 Answers
SOURCE: Hi. My Samsung CLP 300 Laser is playing up. It
The problem you are experiencing is a common problem with this printer. What happens is over time as the printer is used, toner or developer builds up a film on the developer blades. The developer blades meter the amount of toner that the printer puts on the paper to make the image. As the film builds up, less and less toner makes it to the page causing the image to become faint. The black developer blade probally is clogged.
This can be fixed two ways. The easiest and most expensive is to buy a new imaging unit for about $100+. The second is to disassemble your imaging unit and clean the developer blade(s). This can be done in about 30 minutes. I have posted instructions in my Tips section.
Posted on Feb 20, 2010
SOURCE: Is it possible to reset the toner chips on a
Is it possible to reset the toner chips on Samsung CLP 610 printer of all tonner cartridges
Posted on Dec 16, 2010
picipolman
  • 9 Answers
SOURCE: Replace imaging unit error i
Finaly got it.
Pull out the four toner cartridges and also the drum unit , staying in front of the printer , on the right side of the drum unit, you will find a small box with two contacts.
You need to solder a 63ma ( worked for me) fuse in paralel with two rezistors that it contains. It is hold by a small klipp - it is easy to get it out. You also need to empty the waste toner behind the opc , drum or watever you call it . Restart the printer after putting alltogether.
The second solution is to buy a new one but its price talk for itself - close to a new printer :-)
Good luck.
Posted on Jan 27, 2011
Does not get installeed on windows 7
http://www.samsung.com/us/consumer/office/printers-multifunction/color-laser-printers/CLP-300/XAA/index.idx?pagetype=prd_detail&tab=support#
Install the printer driver first then the Smart Panel. Do not connect the printer to the pc until told so.
Sep 10, 2010 | Samsung CLP 300 Laser Printer
My Samsung CLP-300 Laser jet is "burning" the ink when printing mostly dark colors which causes it to bubble and flake off the paper.
What kind of paper are you using? This printer does not work well with glossy paper and will do the things that you have described. Try using ordinary 20 lb copy paper and see if this makes a difference. If you are already using copy paper, then the problem is with the fuser, getting too hot.
Aug 02, 2010 | Samsung CLP 300 Laser Printer
Top roller covered in heat sensitive paper. How do I replace it? please.
If you're trying to say you used label (sticker) paper not rated for laser printers in a laser printer and said labels (stickers) are now wrapped around your fuser then I would tell you game over. The fuser is not replaceable and the machine will not function without it. Sorry.
Jun 08, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
May 10, 2010 | Samsung CLP 315 Laser Printer
Washed out printing both in colour and text
check on your pc smart panel that is install for any error detect for your printer.
follow the the error to get it check is much easier.
hold and press on the button of the printer for 5 sec to check on the supplier infor. that tells you the waer and tear item to be replace.
advice is to replace the toner block (OPC) image drum
if you do not have a smart panel install. you may go to www.samsung.com -> support and download the smart panel program.
http://www.samsung.com/sg/support/download/supportDown.do?group=pcperipheralsprinter&type=printermultifunction&subtype=colourlaserprinter&model_nm=CLP-300&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010200&acc_ia_fl=&disp_nm=CLP-300&model_cd=&menu=download
select the correct version with your OS.
1. OPC image drum - 25K +/- 2. transfer belt 25K +/- 3. transfer roller 20K +/- 4. pickup roller 20K +/- 5. Fuser 25K +/-
Apr 05, 2010 | Samsung CLP 300 Laser Printer
Fuser low heat error
Hi and thank you for using fixya:
This happens when the fuser is not getting hot enough to start the printing process. This could be happening because the fuse is already failing. Try calling samsung see how much is a new fuser
good luck
Mar 23, 2010 | Samsung CLP 300 Laser Printer
How do you reset the Samsung CPL 300 laser
Try opening the front cover and on the side of the blue color barrel is a white L shaped container that catches printer debris. If it is full the printer will give you the red light also. I found it by accident and it worked for me. I don't have the manual but it's woth a try. Remove it and tap it upsidedown over a trash can till it's empty. Good luck.
Mar 16, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Mar 07, 2010 | Samsung CLP 300 Laser Printer
New black toner cartridge for samsung CLP 315 (K4092) only working on one side of the page
Hi
It sounds like the fuser unit has issues and Samsung with the CLP 300 upwards seem to have issues like this all the time.
I would suggest contacting Samsung customer services to see if you can have the unit replaced free of charge.
0845 (7267864)
Thanks
Taz
Oct 28, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP 300 Laser Printer Logo
102 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
