Question about Maytag Neptune MAH5500B Front Load Washer
Washer Not Spinning All Of The Water Out
Our front loading Neptune was not spinning out all the water and leaving the clothes sopping wet. I took it apart and found coins, buttons and other items stuck in the pump impellar. I reassembled everything and when it runs through it's cycle now, it does drain the tub (as verified by watching output of water through drain hose) but it does not go into hyper-spin at the end. Is this some sort of safety reset after the impellar on the pump was restricted or timer problem now. I ended up taking it apart all over again just to make sure there wasn't a stray coin that I missed the first time, but it was all clear and I verified the pump does in fact drain the tub.
  • 1 more comment
  • gamut Dec 11, 2008
    i have the same problem but do not have the skills needed to take it apart and fix it myself. anyone know a reliable Maytag repair service in Los Angeles?
  • ColorTek Dec 12, 2008
    I understand that a certain amount of water is there for balance, but if you re-read what I was seeking assistance on, is that I am not getting the final hyper-spin to 'wring' the water out of the clothes.
    Thanks for trying though
  • Jorgesgirl Dec 12, 2008
    We have the same problem also. We have took the motor apart and it does go back into the hyper spin mode but we are still having to manually drain the machine by taking the hose and placing it in a PVC pipe that we run out the door along the floor. We are so unhappy with this machine! We had three repair men out for other problems with the machine (all within the first year of ownership) and two of them were not even familiar with the machine. The third one was a Maytag service man that they called in from another area. He said he didn't find anything wrong and left. We have had the machine for a year and a half and we have had so many problems. I will never buy Maytag again.
It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
Posted on Dec 11, 2008
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Kenmore washer model 15862400 leaves clothes really wet, why
Possibly a blockage in 1 of the outlet pipes or pump causing water not to drain out properly.
Dec 22, 2012 | Kenmore 24032\24036 Top Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
On one wash clothes came out sopping the next there was no water
Check the drain hose for kinks or blockage. The drain hose should be free in the drain pipe so air can get around it. The drain should be good enough to accept a lot of water all of a sudden without overflowing.
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front load washer not spinning
sp is the pump not running remove the hoses and clean out the pump the pump is in the back the dran hose goes to it
Nov 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
441 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
