Question about Singer CE-100 Futura Computerized Sewing Machine
My new futura keeps beeping during sewing..
What am I doing wrong?
    Scholar:
  • 110 Answers
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down.
Posted on Dec 12, 2008
New machine, plug in turn on and it beeps at me and all the lights are blinking and it is doing nothing. It is a singer futura xl400
If it's new, take it back immediately! You'll end up with it in the shop more than your home. Go to a local sewing machine dealer with a repair shop. They can tell you which brands are reliable, and will fit your needs.
Feb 24, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Futura xl 400 sews 5 or 6 stitches and stops and beeps when trying to sew
Call first to arrange a time...Take it back and ask them for assistance...DO NOT TRY ANYTHING while under warantee or you may void it !!
Jan 10, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
It keeps beeping when I am sewing a straight stitch it say E1
E1 means the machine is out of order, usually turning the machine off & then back on clears it,unless there is something wrong with the computer part of the machine
Sep 20, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer futura beeping every 8 stitches can you solve this .i have changed needles bobbin cases but still doing it but is sewing ok just stops to beep
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Feb 07, 2010 | Singer CE-200 Quantum Futura Computerized...
I have a Futura CE150 and error 19 keeps popping up but nothing seems to be wrong with the thread or bobbin thread
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Jan 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Thread problems
It sounds like it may be a tension problem. Mine does the same...I turn the knob and do a few manual stitches to be sure, then press the bottom button to resume...hope this helps!
Aug 11, 2007 | Singer CE-100 Futura Computerized Sewing...
Beeping
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
128 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
