Question about Westinghouse LTV-37WI 37 in. LCD Television
Black smoke area under tv screen
Runs in a vertical line in center. 3 yr. old toshiba 32in. worth fixing?
    Genius:
  • 1,199 Answers
Sounds like your flyback converter is burnt out and yes if this is the case it would be worth fixing!
Posted on Dec 11, 2008
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Toshiba L675D, black spots
Your screen is shot or partially disconnected. A lot of laptops have the vid card to lcd connect in bracket that connects the screen to the keyboard. I have fixed many by siimply taking it apart and reconnecting the clip but the spots dont sound good. Ebay to buy one or Cl to dump it as a fixer. Either way its a waste of money to have someone fix it for you unless you do it yourself.
Jul 06, 2012 | Toshiba Satellite Black 173 L675DS7049...
Have a black line across the screen on my Toshiba 32AV502R LCD TV, no matter what input I'm using. It started as a bunch of visual "noise" and after turning it off and on several times,...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken
Good luck in solving the problem.
Jun 09, 2011 | Toshiba 32AV502R LCD TV
Toshiba 52xf550u has distorted vertical lines right side of screen problem only 2 years old
All TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
Black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Sep 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
Westinghouse LTV-37WI 37 in. LCD Television Logo
100 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
