Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Channel banner burned into display
From watching a particular channel for extended times, an image has burned into something in the picture making parts of the tv. can anybody tell me what it is and what the part number is. This is an RCA rear projection tv : model HD56W58 (YX1) chassis # APC321
    Genius:
  • 1,199 Answers
All three color lenses may need replaced and if thats the case you might want to consider buying another tv
Posted on Dec 11, 2008
How do you repair a picture tube ( the problem is a black mark like a smuge something not getting power ) in a LG 2013
A smudge or an unresponsive area is what happens when a cathode ray tube displays a stationary pattern or picture for a significant time, especially if it has an area or areas of high luminosity.
The "stationary" electron beam effectively burns off some of the screen coating. Pausing a movie and taking a nap is not a good idea and neither is watching radio on a tv set as the banner can have the same effect.
Cathode ray tubes can be reconditioned and from memory a recon is about half the price of new if you can find somebody still doing the job and somebody willing to supply - crt type televisions are mostly considered not worth repairing these days. A secondhand tube could be the answer if you can find one.
Jun 29, 2016 | LG Televison & Video
How do I remove burn images from a Sanyo TV?
I am assuming this is a Plasma TV? If so, Once an image is burned into the screen,there is now way to remove it. There are some ways to remove temp burn-in images like playing a white screen,and a screen wipe program. But,this only helps if you see a burn-in after watching the same image for a few hours. If the image has been played over a long period of time. "Like a store demo, security camera, ESPN like at a bar" There is no repair for this. And the screen will need to be replaced,and the cost of the replacement is sometimes more than buying a new TV. Sorry to have to give you this bad news. If you bought a extended war.? It may cover the burn-in. Some warranties
will cover that. It is worth a try.
May 04, 2014 | Sanyo Televison & Video
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
My dvd burner dont burn every time i tried it says error i have a 2 year extended service protection
dvd burners require alot of space and memory while doing so. try this download the Imageburn software. then instead of choosing burn to disc, select burn to file. this will create a (NTSC) file folder, will have a audio and a video file in it. open image burn and choose >(create image from files and folders) seen in picture below
audioaholic_0.jpg load the folder you created earlier into this, and make whats called a disc image. once you do this then re-open the image burn and click on (write image to disc) and same as before load the disc image into the window, click burn and there should be a succesful burn!!!
this is a long way to acomplish the same result as burning straight to disc, but this way is less stressful on the system, and almost guarrantees a succesful burn every time!!
Jan 28, 2011 | Computers & Internet
Is plasma burn in real?
Hello.
Well it does not catch any real fire if this is what you mean. What actually happens - PDP (Plasma Display Panel) is "burning out" throughout it's use. Especially if someone is watching TV channels with fixed logo (Like CNN for example). That steady image can get "burned in" into the screen and stay there forever. So it is important to watch different channels and programming so screen does not get any permanent "marks" and spots.
LCD and LED technology does not have this issue because of totally different method of producing image on the screen.
Regards.
Russ.
Aug 18, 2010 | Televison & Video
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Phone keeps saying
thats apart of the service. other than that it could be tha banner, you could go to..... tools and settings, then to display settings, and then banner, then you press customize an you could but like your name or something other tahn that then save
May 13, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Magnavox tube TV - No Picture
If you see any image at all on the screen then it is not the tube. Could be an issue with the tuner or video output of set.
Jun 20, 2017 | Televison & Video
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
