Question about Gateway 835GM (835GH) PC Desktop
Bios Up date problem
I have a 835 GM gateway desktop computer, I did an update on the bios, but before the update complete, the power accidently off. After that, the computer couldn't boot up, when I turn on the power, all I see is the power light and the fan is blowing really strong, usually the fan will turn off after a little bit. And didn't see the video card either. Please help me on this.
Thank you very much.
  • Anhtamxichlo Dec 12, 2008
    thanks for warning but now it's too late, I really want to fix this, the things is I am not sure is it the motherboard it bad, or it's still good. I don't know yet, that's why I need a lot of help from here.
    thanks you very much for respond.
    Scholar:
  • 44 Answers
I don't do many BIOS updates (mostly because they can be fatal to your system if they go wrong) but my general understanding is that if the update does not finish then you are out of luck. Your best bet will probably be to replace the motherboard completely.
Hopefully someone on here has a better idea though...
Best of luck :)
Posted on Dec 12, 2008
  • Brendan Rose
    Brendan Rose Dec 12, 2008
    When you run a BIOS update it is basically replacing a piece of very important software that goes into the motherboard itself. If that software does not successfully install then the motherboard becomes useless. It's called "bricking" because it basically (in the case of cell phones and such) becomes an expensive paper weight.
    If you get the model of motherboard and take it to a computer hardware store they should be able to tell you which motherboard would work as a replacement (assuming the motherboard type is still in production, if not you may be looking at replacing more then just the motherboard).
BIOS UPDATE
HAVE YOU PROBLEM WITH BIOS ?.
YOU SHOULD NEVER UPDATE IF ALL WORKS.
Jul 11, 2013 | Samsung Computers & Internet
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.
When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.
Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
Oct 22, 2012 | Gateway Essential 500 PC Desktop
I need a gateway gt5426e bios update for windows 7 64 bit
There is no bios update for this model. there should be no problem installing 64bit windows 7.
The athlon 5200 is a 64bit chip so there is no problem there. If you cant install and you think its bios related then reset the bios by either shorting the rtc pins or remove the battery and refit after 10 mins. make sure you reset the bios back to defaults before you make any changes to it.
Jul 16, 2011 | Gateway GT5426E Refurbished AMD Desktop...
How do I enter bios on Gateway desktop 835 GM?
All of Gateway's desktops use the F1 or F2 keys to access to the CMOS setup. Turn off your PC, and power on the PC. Press the F1 or F2 key immediately in one second intervals when you see the initial screen displaying the BIOS.(Try F1 key first, if it does work try F2 Key) Hope it helps.
May 28, 2011 | Computers & Internet
Where I can find Gateway GT5678 Bios update
you can get from gateway website > support
Feb 08, 2011 | Gateway GT5678 Desktop PC
My Gateway GM5972 computer shut down and will not start up again, There is no video or audio. The fan still runs, and the DVD drive come on, but computer will not start up
Despite the fans running and the dvd powering up it could still be a power supply problem BUT it really sounds like the motherboard died.
I have built and repaired thousands of computers and your description fits the majority of the dead ones. Replacing the motherboard with a like board is the easiest solution. You can replace with a different motherboard but be prepared for problems. I wouldnt suggest it unless you are a experianced tech.
Apr 09, 2010 | Gateway GM5072 Desktop PC
I have a Gateway 840 GM and I have just replaced
At first check the battery that's on you motherboard. The battery powers the bios on your motherboard. The bios detects you push the power button and turns on the pc. If the battery is dead the bios has no power, so it cannot detect you push the power button and will not turn on the pc. So replacing the battery will solve the problem. If the battery is not the problem, I think your motherboards bios is dead. Maybe it can be fixed but you'll have to send it back to the manufacturer I think.
Mar 29, 2010 | Gateway 840GM (RB840GM) PC Desktop
I need to access the BIOS on my Gateway GT5428 PC
well, the most common BIOS entry keys are F1, F2, F10, and Delete.
push one while the computer is booting, before windows starts booting.
Mar 26, 2009 | Gateway Computers & Internet
Gateway 835GM (835GH) PC Desktop Logo
99 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
