Question about Jenn-Air JCD2389G Side by Side Refrigerator
Flashing light - unable to locate in manual book to what it is.
Refridgerator is tripping main circuit
Local service agent beleives it is the heater element causing the problem. We are not using the freezer and when the alarm sounds we turn it off for an hour. This seems to fix it temporarily (20hrs), now waiting on parts to arrive.
Posted on Dec 15, 2008
Advice on RCD tripping
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
We're is the fuse on the Jet 3
I hope this helps:
The main circuit breaker is located on the front of the battery tray.
Main Circuit Breaker: The main circuit breaker is a safety feature built into your power chair. When the batteries and the motors are heavily strained (e.g., from excessive loads), the main circuit breaker trips to prevent damage to the motors and the electronics. If the circuit trips, allow your power chair to "rest" for approximately one minute. Next, push in the circuit breaker button, turn on the controller, and continue normal operation. If the main circuit breaker continues to trip repeat- edly, contact your authorized Pride Provider.
Here is a link to the owners manual too:
Jan 31, 2013 | Health & Beauty
Start light flashing, wont wash
see this and fix it. if necessary replace it. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Washing Machines
I have service manual for my kds60a2020. have red light flashing 6 times manual says its a power problem. but does not say what to change. pls help
Error code for power can be related to many issues which need circuit probe with voltage check and isolation.
Proceed only if equipped with the manual to detach the power circuit and test for voltage , connect to the main unit and see the point of trip over to identify a short or malfunction.
Dec 06, 2011 | Sony KDS-60A2020 60" HDTV
Operation light flashes on three times and the timer light continuously flashes, the unit will not work
Please remove the power for few hours , push down all panel buttons to drain off residual voltage on the panel. It seems that the main processor has encountered an error due to many reasons and so it is best to start by resetting the processor.
If there is no result then the main output must be checked, the compressor, the pressure switch and the fan circuit must be checked. If there are errors in any of the motors the excessive load will not allow the motor to start but would show a trip as circuit break
Sep 03, 2011 | Fujitsu Heating & Cooling
Currently have this refridgerator which has been under warranty with the vendor we purchased it from. In the past 2 months, we have replaced two of them as the compressor keeps going. All appliances...
Julie - this does sound very strange. It is highly unlikely that all your appliances are on one circuit. In the U.S. (and every other developed country) there are standards for wiring. Refrigerators, along with other major kitchen appliances such as dishwashers, microwave ovens, trash compactors, garbage disposals, etc. require separate and dedicated circuits. That is: these circuits are not shared with other plugs or appliances. This is largely because of the amount of power each requires. Most home lighting and outlet wiring is geared to 15 and 20 amp circuits (except for dryers, ranges, etc.) and having more than one of these appliances on one circuit would cause fuses to open or circuit breakers to trip.
The issue is probably a power quality problem. Voltages that are too high or low, open or split neutrals, poor connections at receptacle terminal screws or even the receptacle slots that grip the prongs of the plug - are all common sources of power quality problems. You should measure the voltage on this circuit (and others) to be sure it is what it should be. If unable to do this, you should contact your electric utility or qualified electrician to do it for you.
I hope this helps!
Dec 07, 2010 | Whirlpool EB2SHKXVQ (221 cu ft)...
Refridgerator trips the gfci outlet but will run on a regular out
Do not run a refrigerator or any other appliance on a GFCI that has a start load greater than the GFCI rating. Your refrigerator has a greater start load.
Jun 05, 2009 | Refrigerators
New Kenmore refridgerator trips circuit breaker
1. Check to make sure the receptacle is wired correctly. Black wire goes smaller of two inlet holes, white goes to the larger.
2. Check to make sure that the smaller blade of the 2 prongs on the ref. plug is not grounded. Use ohmmeter from smaller blade to fridge housing
Apr 25, 2009 | Kenmore Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Logo
69 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
