Question about ASUS P5B-VM DO Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
I just bought an Asus P5B-MX motherboard with intel coreduo up to 64 bitand 2gb ram all installed.
The leds and internal speaker are all connected.
The power supply is an Atx 450w.
All is connested well and i use the onboard vga.
Dvd and Hard Disk are connected.
THE PROBLEM:
When i switch the power on every thing runs normaly, the Green Led is on for power ,the dvd open and close and the cd inside is spinning ,the HD is running (I can sense it),
the cpu fan is running but THE DISPLAY is not showing any activity and the whole thing doesn't boot .
What is the problem?
I tried to take off the Ram stick and the speaker went crying 3 times,
when i tried to restsrt,
when i put the ram again, the speaker stops
i can not figure out what is hapening , may be it is because of the 64 bits cpu?
but it is written on the booklet that it is ok to run 64 bits with usual components:
the problem is that the normal start up of the bios is not booting.
Check your Video Card. Perhaps Bad driver or a malfunction
Posted on Dec 12, 2008
3 Suggested Answers
  • 69 Answers
SOURCE: On barebone asus p5b-mx 1st try won't boot display but led is on
Hi There,
Disconnect the hard drive ribbon cable from the mother board and try again. carry on disconnecting each component at atime and trying again. Leave the video attached. this is going to be a process of elimination. sooner of later you will find out where the problem is.
My personal feeling is that the hard drive is connected incorrectly.
Let me know if you want further help.
Regards,
Philip
Posted on Dec 09, 2008
map9966
  • 2351 Answers
SOURCE: Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
ASUS MOTHERBOARD P5B-MX WIFI WON'T DISPLAY
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Dec 13, 2008 | Computers & Internet
Asus motherboard p5b-mx wifi won't display vga
this can be caused by a number of issues the leading being RAM (no post beeps at all). before you do anything else pull all existing RAM and install a KNOWN GOOD STICK in their place and try again.if that doesn't work try resetting the mb (see the owner manual on how to do that) bios settings to defaults (this generally selects onboard video). if you have an installed video card within the system also remove that (even though you aren't using it). is that memory compatible you have there with the board? if its too slow the stick may be fine but mb may not "think" so. do you have keyboard "flash"? is the hard drive indicator constantly lit? how about cdrom drives and/or floppies? can you eject same? all this points to incompatible or "bad" memory as the main culprit.
Dec 12, 2008 | Computers & Internet
ASUS P5B-MX/WIFI MOTHERBOARD : NO DISPLAY
If you just bought it, I suggest you contact the store where you bought it to claim the warranty.
If you keep trying to find solution, you might do something that void your warranty.
Asus p5b-mx motherboard no display no beep
when ever you are getting the beep messages after you remove the ram card and connecting the tower to the power cord it shows that mother board is functiong normally so no problem with the mother board .try this steps so that it may resolve the issue.
1. No Boot:
. Check the cables
. Check with the socket on the wall as well as surge protector
. Swap the power cable with the monitor
. Power drain ( after removing all the cables press and hold the power button on the tower for 10-15 sec and the re-insert the power cable and connect the monitor and check)
Monitor does not power on
Check with the power cable
Check with the cable from the monitor
Swap the cable
Power drain
If the cust gets the power on the monitor and even the tower but still if he cannot view anything on the screen
Dec 11, 2008 | E-Machines eMachines Desktop PC
Good luck camlamm!
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
Hi There,
Regards,
Philip
Dec 09, 2008 | ASUS P5B-VM DO Motherboard
Psb-mx/wifi
The problem - I guess - is that this CPU is not recognised correctly by the board. To solve it, just update to the latest BIOS, using either AsusUpdate or manually from www.asus.com
Dec 06, 2008 | ASUS P5B Deluxe/WiFi-AP Motherboard
P5b-mx
Is the CPU fan spinning? have you tried a different VGA card? (though if it's a brand new board, I'd be taking it back as it'll still be covered by the warranty)
May 29, 2008 | ASUS P5B-E Motherboard
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
ASUS P5B-VM DO Motherboard Logo
716 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
