Question about Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers
Learning remote codes for my harmon kardon avr354
I seem to not be able to get certain codes provided to work on my HK remote.
Insignia® - Blu-ray Disc Player with 1080p Output Model: NS-2BRDVD
comcast dct6412 III receiver by motorola.
Sharp - 52" 1080p Flat-Panel LCD HDTV - Black Model: LC52SB55UThe remote takes 3 digit codes.
It's driving me crazy switching between 4 different remotes. Thanks if you have any info.
A) Place the two remotes so that their IR transmitters face each other
end to end, separated by about one inch. The
AVR 354 remote’s transmitter also serves as an IR receiver during
the learning process.– AVR 354 and Original Remote Head-to-Head
b) Press the Source Selector for the device mode you wish to learn
a code into, and place the AVR 354 remote in Learning mode by
pressing and holding the Learn Button until the Source Selector lights
up, then release.
Learning Remote Commands
c) Press the button on the AVR 350 remote you wish to program with
the new code, and the Source Selector will flash once. You may
learn a new code into the following buttons: Device Power On/Off,
Alphanumeric Keys, Last Button, Back/Exit Button, Menu Button, Navigation Buttons, OK Button, Disc Menu Button,
the four Teletext Buttons, Channel Up/Down, Volume Up/Down,
Mute and the Transport Controls (including Record).
d) Press and hold the button on the device’s original remote whose
code you wish to “learn” until the Source Selector flashes three
times, then release.
e) You may program additional buttons by repeating steps c) and d).
Press the Learn Button once to exit Learning mode, or wait for the
remote to “time out” and exit Learning mode on its own after about
30 seconds.
Posted on Dec 12, 2008
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
Can I connect guitar to my Harmon Kardon receiver
Sorry. They are not compatible. The headphone jack is an output but you need an input for a guitar or bass. You will certainly damage the HK if you continue. There are no compatable inputs on the HK. The inputs are meant to be used with a 300mv output device, such as a CD or DVD.
Oct 02, 2013 | Harman Kardon Audio Players & Recorders
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
Installing a Harmon Kardon on a 03 Ultra
The 23 pin main connector is a direct plug in from the 03 bike to the HK unit. The only issue would be if the original 03 was using the accessory connector as well. The accessory connector on the 03 is another 23 pin. It's a 35 pin on the HK. For more info, or to discuss this further, contact Iron Cross Audio (
Nov 18, 2009 | Harley Davidson 426290 AM/FM Radio
I need the correct universal remote code for Harman Kardon AVR354 I have several types of Universal Remotes. None of them work. The latest one I tried is Radio Shack HDTV Remote (7 programmable)
The Code that you will need is the code that comes with the "universal remote" not the receiver's code. Every remote manufacturer will have a different code to control the same piece of product. Look for the manufacturer of the remote's website and search thru support. If you have the exact model # of the remote you are trying to use, post a comment and I can try and find it as well. Hope this helps
Nov 07, 2009 | Harman Kardon AVR 335 Receiver
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Harmony remote with Harmon Kardon receiver
HK AVR 347-I took it back- everyone was frustrated and the verdict was that it just doesn't work. I have a Dennon now and it doesn't sound as good as the HK but it works most of the time. Not sure it the Harmony is the problem. I'm reading the Dennon manual now and it seems the Dennon remote can do what the Harmony is trying to do. Harmony support is awesome and we'll keep trying. Sooo- was there a trick to it?
May 13, 2008 | Logitech Harmony 890 Universal Remote
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
2,330 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
