Question about Panasonic KX-T7453 Corded Phone
Transfer Intercom Call
Is there a way to transfer intercom calls? My boss will page me and want me to transfer him to someone else.
  • Panasonic Master
  • 2,460 Answers
This works on a TDA, so I think it will also work on a TD. The key is 43. When you page someone, you can pick up that call via 43 which gives you an intercom call. Now, your transfer key works, putting the other intercom call on hold and giving you dial tone.
Carl
Posted on Dec 12, 2008
Transferring an intercom call
You cannot transfer an INTERCOM call.
Aug 27, 2012 | Lucent PARTNER18 Corded Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
How can i transfer calls from one phone to another?
First make sure you give each phone an ID on your system. You do this by going into the menu and go to phone options then scroll down to phone ID then press the intercom station button you want assigned for this phone. To transfer call: With caller on the line just press transfer then the intercom station button of the room (intercom station) you want it transferred to. If it is not answered in 45 seconds the extension stops ringing and call is placed on hold
Dec 06, 2010 | RCA 25414RE3A - - Phone
We have lucent phones and have know ideal of how to transfer or use intercom
To use both the transfer and the intercom it,s necessary to know the extension numbers of the phones your trying to call or transfer to. To find out what the extension number is on those extensions either press feature 00 (if the extension has a display) the extension number will be displayed on the screen, if the set doesn't have a display then you can use the intercom to call a extension that does have a display. To use the intercom press one of the intercom keys below the first two line keys and enter in the extension number of the persons phone you wish to call. To transfer a call, while talking to the caller press the Transfr key(above the hold key) then the extension number of the of the persons phone you wish to call then hang up.
Oct 14, 2010 | Lucent PARTNER18 Corded Phone
How to transfer
While your on the line with the caller, press the Transfr button(above the hold key) then enter in the intercom number of the person you wish to transfer the caller to. You can either wait for the person your transfering the call to to answer his extension before you tranfer the call or you can hang up after you enter the intercom number, either way, when you hang up the phone after entering in the intercom number, the call is transfered to the extension.
Aug 09, 2010 | AT&T Lucent MLS-12D Phone
How can I transfer my intercom call to a diffferent intercom?
you should be able to just put the first intercom on hold and then pick up on the second one.
Sep 18, 2009 | Panasonic KX-T7453 Corded Phone
WE HAVE RCA EXECUTIVE SERIES PHONES INTERCOM LIGHT FLASING
RCA Executive Series Phone: How do you place the caller on hold and then intercom to another, then transfer?
Mar 17, 2009 | Lands Phones
How to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Aug 18, 2008 | Panasonic KX-TG5632 Phone
Intercom
Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
From any station, pressing the speed-dial button for another station's station number will page that station.
Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
Oct 23, 2007 | RCA 25414RE3 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
510 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
