I need a schematic for a orion tv model# 1934, board #tma525a
The problem is I have a horizonal line; No vertical deflection.
I have already replaced the vertical output device and no change.
Dutchman
  • 3 Answers
SOURCE: 20 inch T.V.
I have had past experience some years ago with new or fairly new TVs which had vertical deflection failure. I suggest Checking all coupling capacitors on the circuit board around the vertical deflection circuits. One way to check is to turn the set on and slightly warp the circuit board and see if the deflection restores. I have found bad solder joins in several sets which lost the Vert. deflection and was simply repaired by re soldering the connections.
Posted on Sep 01, 2006
MikeNJ1964
  • 398 Answers
SOURCE: tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Posted on Jul 05, 2007
  • 236 Answers
SOURCE: orion TV 1934
You might try substituting a new fuse. Be sure the replacement has the same rating. You may have a short in your power supply and depending on the type of supply the supply may not start up if it has overload protection. Stargazer
Posted on Aug 10, 2007
  • 579 Answers
SOURCE: SANYO AVM-3289G no vertical deflection
It isn't a transistor, It will be an I.C. with a part number that probably starts with an LA_ _ _ _ . It will be on a heat sink and be in the vicinity of the connector going up to the yoke. Try replacing that. But first, check all the electrolytic caps around it for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. May have lost power to the I.C. as well. Look the I.C. up in the free NTE crossreference at nte.com get a diagram of its pinout to find what pins the power and outputs are on.
Posted on Dec 31, 2007
Shuttle83
  • 1139 Answers
SOURCE: orion 1934 19 " tv
Hello anglersquest,
It is usually located near the power supply section. unplug the TV, open the back of the TV and look for a small glass cylinder with two metallic ends. This will be the fuse, now to check it do a visual inspection and you should see a clear cylinder with no internal dark smuges (good) has smudges (bad). Then if you have an ohmmeter set it to the 1xR setting and measure the fuse ends it should read 0 ohms if the fuse is good and no reading if the fuse is bad.
I hope this helps
Thank you,
Shuttle83
Posted on Aug 23, 2008
On screen horazantal white line
May not be an easy fix:
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke
May 27, 2014 | Samsung Televison & Video
I got the problem for my Panasonic 21 TV (CRT type) where's Vertical line across picture tube when the brighness adjust high. The vertical I.C already changing. Any solution > Thank you
Hello
Have you recently replaced its Line Output Transformer [LOT]?. If so have you replaced it with same type and number? Verical bars are due to LOT to Deflection Yoke mismatching. It is known as "Yoke Rigging" technically. Replacing the vertical Ic won't help in this problem . If you have replaced the LOT, the replaced one is not orginal. Ok
Oct 31, 2010 | Panasonic Televison & Video
I have a toshiba regza 42inch lcd for six weeks and this morning when I switched the tv on a long dark line appeared on the screen. Before I go to currys can some one please tell me whether it's something...
you can do this yourself by opening the back cover of the television
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Jun 01, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Have a 29 inch 5 or 6 yr old rca color tv lately we get a colored horizontal bar across the top of the screen and the other day we have fuzzy black lines across the entire screen
May 30, 2010 | Televison & Video
The picture went out. Still have sound.
Good luck..
May 23, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
When I power on my Mitsubishi CS-35313 tv, I only get a thin horizontal line across the center of the picture tube. What could be the problem?
There is a failure in the vertical deflection circuit. Typically there is a vertical output i.c. that provides the deflection vertically. The i.c. itself is a fairly common component to fail. There are some lower power circuits that feed this output device that also could be the problem. When the electron beam in the tube is not deflected vertically it "writes" only horizontally across the center of the screen thus resulting in a single trace. Be careful not to leave this at high brightness for any extended time as it can "burn in" that area of the screen. Unless you are a "techi" this is a job for a qualified technician. Troubleshooting would be in the vertical deflection section of the set. Most of the parts are not expensive in themselves, except for the deflection yoke which sits around the neck of the tube. The cost to repair would typically be the shop labor.
Nov 25, 2009 | Televison & Video
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
Vertical line in center have replaced vertical output ic
If the line is vertical then the problem is no horizontal deflection. The vertical chip is probably fine.
Check connections around yoke (thats the connector with at least four wires that goes up to the coils around the neck of the tube)
Maybe that TV has two horizontal output transistors. One for deflection and one for high voltage? Check both of them. Look for bad solder joints!!!
May 21, 2009 | Sanyo DS31520 31" TV
HORIZONAL LINES
that is because you have a defective vertical deflection circuit, check all the caps and if that does not solve the problem replace the vertical output ic
good luck
caypianan@yahoo.com
Oct 27, 2008 | RCA F32650 32" TV
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
