Question about Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 ADSL- Setting Security Settings
Tried but failed ... so far.
In the Zoom Device website I have chosen either WPA or WPA2. Then in the Zoom Network Props on my PC, have chosen either WPA2 - Personal; and or WPA-Personal (No single WPA choice as is suggested in the manual). Sometimes it confirms that I have succeeded, but when I go wireless, I loose wireless access (time and time agian). I am running on MS Vista Home. I am also getting very frustrated! Hope you can help me.
Yes .... problem now solved. Helpful guy from Zoom got back to me, but the real issue was ..... you must (with talktalk at least) use your IP password as the Passphrase. So the instruction to select a Passphrase is understated. It needs to be more specific. I used the WPA 2 setting in the Zoom Webpage Device Wireless Setup, and then the WPA2-personal, in Zoom Newtwok Properties Section on my PC.
Posted on Dec 12, 2008
Wirless works for the netwoek but cannont connect laptops or i pods. they pick up the router but every password showing on the set up pages denies access
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 16, 2011 | Zoom X6 (5590) DSL Modem (55900003)
Can't connect ipod to Zoom adsl x6 modem.
I found if I removed the WEP security on an X6 the Ipod connected without any problem.
I tried WPA and WPA2, and these won't connect either.
The password it wants it the one you used to generate your WEP code when you first set up the router. If you don't know what that is, then you'll have to reconfigure it with anew one.
Also, an IPod Touch may connect if you choose Other connection in it's network settings, and then tell it to connect to WEP.
Jan 03, 2010 | Zoom Computers & Internet
After installing the router it was working fine. I went in to set up wireless security and now the internet light stays red.
Probably means that the security is turned on, if the wireless doesn't work even after you have entered the right password then press and hold the reset button on the back of the router to restore it to defaults - factory defaults just like it was first powered on.
Oct 07, 2009 | Zoom X6 Adsl Modem/router Rohs...
My Toshiba Satellite A55 S106 wont allow WPA2 which is what my internet can I fix this or is it hopeless?
If this is for XP, you need to update to SP3 which has WPA2 support now. Vista comes with it anyway. You might have registry issues if SP3 WPA2 fails to install properly. You could also change you router WiFi security to WPA or WEP.
Jul 24, 2009 | Toshiba Satellite A55-S106 Notebook
Wireless WPA connection problem to Zoom ADSL X6
ya there is filter oing inbound also check port forwarding in router and check firewall to.
Default ip for access belkin router is
May 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
IPod connection to Zoom ADSL X65590 router
you have to log in at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Dec 26, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Security Settings
Type in right at the top of your brouser,not in google but right at the top where it says etc. delete this and put you ip no ( in its place
Sep 08, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask:
      • Gateway:
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server:
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Unable to apply any authentication for the Wireless
there should'nt be a problem setting WEP security or an other unless there is a firmware problem, as you simply select security, then the method e.g. WEP, select hex, then open system amd type manually your values for a chosen key number from 1 to 4.
Jul 25, 2007 | Encore WL ROUTER |ENHWI-SG 54M 11B/G...
Difficulty in first time support with zoomX6 5590
Hi Maybe i could help you. I have installed this modem before for an ISP provider. Please give me specific task you want to do and I will explain what to do.
Apr 30, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 (5590) DSL Modem (55900003) Logo
246 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
