posted by deerdesign on Mar 19, 2007
Hi all,
my question is simple: how to set the Header to the combination key "Control" + "3" ?
The D130 manual is not clear.
It doesn't show a practical example.
I tried more, but without results. :(
I need to set header reading barcode.
Thanks in advance,
Fabrizio.
Best Solution
posted on Mar 22, 2007
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below:
The extended Header/Terminator keys for Wedge Interface users can be
customized by defining them through a simple keyboard setting procedure.
For example, the Numeric Keypad keys can be set for use as Headers or
Terminators by substituting the default extended keys using this procedure.
The type of computer or terminal must be selected before activating the keyboard
setting command.
Press and release a key to set it.
Some characters may require more than one key pressed simultaneously during
normal use (refer to the manual of your PC or terminal for keyboard use). The exact
sequence must be indicated to the reader in this case pressing and releasing the
different keys.
Example:
If one has to press the "Shift" and "4" keys simultaneously on the keyboard to
transmit the character "$" to the video, to set the "$", press and release "Shift" then
press and release "4".
Each pressed and released key must generate an acoustic signal on the reader,
otherwise repress the key. Never press more than one key at the same time, even if
this corresponds to the normal use of your keyboard.
Press "Backspace" to correct a wrong key entry. In this case the reader emits 2
beeps.
Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard
setting procedure. "SHIFT" must be repressed for each character and cannot
be substituted by "CAPS LOCK".
Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page;
http://www.datalogic.com/_vti_g2_dwnlDet...
Hope this helps :)
setting command.
different keys.
Example:
beeps.
Hope this helps :)
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Datalogic Heron D130 Handheld Barcode
Email this problem
Email this problem
Can you Help with these Barcode Scanners problems?
Repair Service
Find Barcode Scanner Repairman Near You:
