Se error on westinghouse mastermind 711 any ideas?
  • din0806 Dec 14, 2008
    Apparently a pin had come out of a shock absorber and caused uneven spinning, setting off both the sensor and the brake.
    President:
  • 373 Answers
SE error is a sensor problem.This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Dec 12, 2008
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Jan 07, 2011 | Westinghouse Washing Machines
Westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Aug 24, 2009 | Westinghouse Washing Machines
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
0E Error
Apr 10, 2009 | Westinghouse L2046NV Monitor
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing Machines Logo
659 people viewed this question
Top Washing Machines Experts
