Question about D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR 655- losing connection with ntwk is "INVISIBLE"
DIR 655, HW A3, FW 1.21- when I set router not to broadcast SSID (invisible mode) I lose connection to my Blackberry. Other wireless devices maintain connection. Upgraded from a D-Link DI 624 (circa 2001) and basically copied the same settings. Currently I have desktop, 2 laptops, 1 mac book, 2 blackberry's- both blackberry's lose connection upon activating "invisible" mode.
Any ideas as to why? Thanks in advance
  • Anonymous May 03, 2009
    Blackberry Curves will not connect with D-Link DIR-655 when SSID is set to "invisible". Upgraded from a Netgear wireless router that was set to NOT broadcast the SSID, and when manually entering the SSID into the Blackberry it was repeatedly found just fine. Thoughts, anyone? WEP vs WPA vs. WPA2 problem? 802.11b/g vs. n problem? Thanks for any help...
  • 30 Answers
Unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
Posted on Dec 13, 2008
How can i fix dir 615 ssid stop broadcasting issue?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password
Step 3: Under Setup Select the Wireless tab
Step 4: On Wireless Tab - Select Invisible if you do not want the SSID of your wireless network to be broadcasted by the DIR-615. If Invisible is selected, the SSID of the DIR-615 will not be seen by Site Survey utilities so your wireless clients will have to know the SSID of your DIR-615 in order to connect to it.
Sep 08, 2014 | D-Link DIR-615 Wireless Router
Internet connection lost every 30 minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
I lost my password
Take look at the following link. This will reset your 655 to the factory defaults (including the password).
NOTE: You will lose any settings you have made, and will have to redo them.
http://www.dlink.cc/d-link-router/dir-655-forget-password-and-how-to-reset-it-back-to-the-factory-default-settings.html
Sep 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have a D-LINK DIR-655 in use. It was fully functioning up until yesterday when wireless suddenly stopped broadcasting. The wired connections all are functioning properly , but no laptop or other device...
Try resetting the router back to default settings. Press and hold the reset button for 10 secs. then release. After the reset, try accessing 192.168.0.1 once again and check if you have the complete details on your wireles LAN section.
Sep 03, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
How do I make my D-link extreme N dir-655 stop losing connection throughout the day. Is there a power setting that I can adjust.
There could be any number of things causing a wireless router/computer to lose connection. Please click on this link and follow my instructions to find a possible solution to your problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
May 22, 2011 | D-Link Xtreme N DIR-655 Wireless Router
My d-link dir-655 wireless router loses connection every 5 to 6 hours. How do I make it stop
I would like to have the highest level of security on my home network, so my wireless router is set up with MAC filtering on, and the network is "invisible." I have entered the MAC address for my...
The problem you are having is that on your computer you need to set the wireless network to "connect even when network is not broadcasting"
Setting the network to invisible stops the router broadcasting the SSID (Name of the network). If your computer is only looking for SSIDs that are being broadcast it will not connect to the network when you set it to invisible.
Dec 18, 2010 | Computers & Internet
No Wireless Connectivity
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from other wireless routers and access points in your area.
Oct 09, 2009 | D-Link DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
1,365 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
